500 KLM for nothing...
Results 1 to 19 of 19
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default 500 KLM for nothing...
    If I was more attentive, I could have saved myself a trip.....
    The clock spring behind the steering wheel in my year 2000 XM is toast and, I had been down to Roger Wilkensons' place near Warnambool a couple of times for parts. You would think that I would have noticed that his cars are earlier and do not have radio controls on the steering wheels thus denoting that the wiring behind the wheel is completely different.
    Nice drive though - car ran faultlessly (apart from the flashing "airbag" light).
    Guess I will have to do the rounds of the wreckers looking for a Peugeot 605....
    Warren
    San Diego, California, USA
    3,543
    Quote Originally Posted by WRB View Post
    Warren
    About round trip from here to Malibu. Not short, but enjoyable.
    May I make a suggestion, having gone the path? Copy down the part number, and see if it is really just 605/XM. It may also be then-current 405, Berlingo, and so on. I would check anything in the PSA range for that P/N that has steering wheel controls, but without airbags. Also, before you pull that clockspring, make absolutely 100% certain that wheel is on center before you pull it. Avoid one where the wheel spins freely. An in/out test with a simple continuity check at the terminals is not a bad idea, and pretty easy to do.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I have access to the Cit parts site but, it is not listed or illustrated anywhere.....Just the housing and 2 side switches
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I think the only way I am going to be able to sort this is to "fool" the airbag controller that the airbag is still working. I do not care about the radio controls as they never worked anyway... Anyone know what resistance I should use? (yes, I know it is illegal!)
    There were just not enough of these made for me to be able to find a wrecked one and, without a part number I cannot check other manufactures
    lost
    11,055
    Icon6
    G'day,
    you drive a French car, don't you worry about that.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Might need to get a roadworthy - I want to get back into a CX
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,404
    Nice Sunday drive in a comfy car and you got to say hello to me!
    So did you keep the steering wheel from the green car after all?
    Roger
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    The one I removed today, I put back on but, forgot to bring back the single spoke one. I will be doing some touring of the south coast in a month or to (Just to get out of the bloody house - I can work on a laptop) so, I can drop it off then. I will let you know when I will be in your area.
    Cheers and thanks
    Warren
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,369
    When I saw the thread title I thought I was about to be engaged by another of those sites that claim you can run your car on water......
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I will give it a try Kim - let you know what happens
    16,698
    It's an XM ... it'll probably do it itself for you soon...... The bonus of them adding coolant into the combustion process is it make the piston and compression area lovely and clean.
    PS: You don't want a CX ... there no challenge at all to work on compared to an XM....
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I have actually seen a V6 with the head off and the cylinders filled with green fluid - saves having to de-coke them....
    10,094
    Do you mean this rotating switch? The parts diagram shows it changed from RP 6931, which is some time late 1995. I believe they are common to a later Xantia and some Xsaras. This is different to a Comm unit as found in all later models like the C5, which is an integrated assembly with a clockspring and stalks. With the XM, you can change the stalks separately.
    There is also a steering angle sensor for the Hydractive suspension, listed under Suspension - Hydroactive Suspension as part# 527324. It seems to be common to Hydractive Xantias after RP 6384 (May 1994).
    All are listed as still available by the part numbers. However, I suspect 4112X7 may actually be NFP/NLA.
    p.s. Another NFP part is the little push to open spring catch for the keypad cover 7588F0. There may still be some dealer stock, but I have a small supply of a replacement part to fix that if needed.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Thank you David,
    that is the part. Mine has the radio controls.
    The steering wheel angle sensor just clips in front of it as well.
    My keypad door is broken so, please PM me with cost.
    cheers
    Warren
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    PS can you give me the part number for #7 also (it is cropped of the bottom of the list) The circuit board on mine got cooked with the rest of the electrics
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    pppps Can you please let me know what section you found that diagram within the Cit parts list?
    thanks
    10,094
    Something like ...
    The rotating switch is in Steering-Steering Wheel Controls. Then choose the Airbag after RP 6931 option.
    The angle sensor is under Suspension-Suspension system, then choose Hydroactive Suspension W/O anti-roll (i.e. not Activa) from a very long list.
    Part number for #7 is given as 6239A5, but also marked as NFP/NLA. Seems to be unique to the XM II. There may be similar parts in a Xantia you can work with or you'll need to chase it from Europe.
    The keypad part I have is the part that fits in the console. You have to remove the keypad and surround to get at it. If the lug on the door is missing, then the bit I have won't fix it. Send me a pm with your name and postal address.
    You can have ABS warnings for a range of reasons of course and warnings are common on an XM. The brake switch is part of the pedal pad and then you also have the various connectors to give grief.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Thanks, I will check the keypad cover tomorrow
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    All steering wheel electrics are still available (universal across a number of models). Not very expensive from my supplier in France...
