CX thermo fans
Results 1 to 15 of 15
  • 1 Post By Greg C
Thread: CX thermo fans
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default CX thermo fans
    I have one fan working when normally both fans come on together.
    Should I start with checking the fan first and then maybe relays?
    If the fan motor is dead what then?
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    754
    Apparently it is not uncommon for the shaft to seize. Check to see if the fan will spin by hand. Getting the old one out to replace it might be a bit of a challenge if my effort with one of mine last year was anything to go by.
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Check the fans and work backwards. I have had to clean the connectors at the fans on more than one occasion. It would be very rare for a fan motor to die, but if so plenty of second hand ones available or of course CX Basis for a new one.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Jan 2011
    749
    Its working again today. So must be poor wire connections.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    Member Houtan's Avatar
    Apr 2014
    Tehran, Iran
    72
    Hello Adrian, First connect a wire directly from 12v + battery to the + pin of each fans, check if they are working or not or if working they are noisy or working good. If they are working go for relays. but I guess this is relay or fuse problem because in all two fan CXs if one of the fans damages the other one must working.
    San Diego, California, USA
    3,543
    Quote Originally Posted by IE23 View Post
    Don't assume too far, Adrian. A poor connection is just that- poor. Play with it a little and check to make sure the connection isn't arced, burned or otherwise compromised. What little movement that knocked it into a connection today can knock it out tomorrow.
    Apr 2014
    Tehran, Iran
    72
    Also check the thermo switch on the radiator and its connection.
    3,543
    Quote Originally Posted by Houtan View Post
    Excellent point- thermo switches do get weak with long use.
    16,691
    There's no simple fix for this one. A poor connection just about anywhere in a series/parallel setup like the CX will generally leave you with no low speed fans, and only one high speed fan (think about how a series circuit works). Check the series/parallel relay (yeah fun finding that, look for the relay with the chunkiest wiring). It'll be burnt and melted if the wiring is suspect due to the heat generated by the dodgy connection. The wiring down into the nose can also be full of rott ('cos this is a pommy car). The spade terminals at the fans will probably be full of corrosion too.
    On these pommy cars you really need to snip out every wiring connector and chase back up the harness for some shiny, - non rotten - wire, then solder in a new connector and wire. For the wiring connetors that are just there for ease of assembly, and don't actually allow anything to be unplugged. Best bet is to snip these out and solder the wires together.
    Fun right
    Jan 2011
    749
    this is playing up again, back to single fan. It's the plug for sure. I jiggled the plug and instant double fans back on again. The wires move about easily within the plug and the connection is weak. Any ideas where I can get a new 3 pin plug?
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    3,543
ID:	75457Click image for larger version.
ID:	75458Click image for larger version.
    Long shot is the dealer. If that's a Bosch sensor (likely is), you can also try a Mercedes, BMW, VW or Volvo dealer. Look through the parts books. A good quality aftermarket parts source may have a pigtail with leads already attached, too. Take your pics and match it up.
    11,186
    Couldn't you just bypass that plug by fitting female spade terminals to the three wires and going directly to the male spades on the switch?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Oct 2003
    1,304
    My thought too but why not try some electrical contact cleaner like Servisol and give them a good clean, then with some needle nose pliers nip the corners of the plugs in the sockets and then refit. I can see some oxidation on on the the plugs that needs cleaning off.
    JohnW likes this.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    3,543
    I was thinking about that too, but I hesitated for a couple of reasons: 1) getting loose 6.3 spades of a good quality are not overly common or easy to get and 2) crimping can be a problem because of the amount of current you're passing. The crimps need to be tight and well made or you'll have the same problem or worse a year from now.
    Going your route isn't bad, but for a use like this I would strongly suggest the 6.3 spades that have the heat sealable wire end. You want the additional support strength and insulating properties. If a pigtail is found, use the heat sealable butt splices. A set of 3 is like 2.50. If you really want, I can post a few to you gratis.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Thanks for asking, I only have one fan working as well
