2CV Iskra Starter to paris Rhone connection ?
Results 1 to 12 of 12
  • 1 Post By Hotrodelectric
Thread: 2CV Iskra Starter to paris Rhone connection ?
    Feb 2011
    230
    Default 2CV Iskra Starter to paris Rhone connection ?
    Im putting in a Paris Rhone starter to replace the Iskra
    The big + wire and a small yellow wire go on the + terminal , got that OK
    Now
    The other small yellow wire on the Iskra , does that go on the spade terminal of the paris Rhone?
    The Iskra does not have a spade terminal
    16,698
    I'm confused. How does a starter motor have more than two connections. You have the main battery power feed, the solenoid power feed...... How can there be another (unless you have to manually wire a solenoid earth wire in ... which is weird way of doing things). Where does the wire go if you trace it back. 12volts or earth?
    Feb 2011
    230
    Got it now , did not see the solenoid feed on the underside back of the Iskra , wish me luck on the hook up I have had smoke from the main loom in the past but she still runs ,,,lucky ?
    Thanks for the reply Shane
    Feb 2011
    230
    It runs , Thats good
    San Diego, California, USA
    3,543
    Icon14
    Quote Originally Posted by Renburg View Post
    +1. It seems you followed my Two Basic Rules for Electricity:
    1) You have to hook it up
    2) You have to turn it on.
    Violate either of these two rules, and no amount of head scratching or cursing will fix your problem.
    daffyduck likes this.
    16,698
    You forgot step 3 where you jump around swearing like a lunatic because all of the smoke just escaped from the wiring.... and it's now just one big molten mess
    3,543
    I mention the Two Basic Rules- I hadn't said anything of all the corollaries....
    I try not to do the jumping and swinging any more- I'm too old. too mature and too fat to do that. Far easier to simply do it right the first time.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,468
    Step #4 is extinguishing the fire. This at least confirms that your battery is good.
    John
    Feb 2011
    230
    The connections made sense when I could look at the back of the thing , its a little hard bending over , in a dark garage , seems OK cranks slower than Iskra , we shall see
    16,698
    Was the Iskra a geared reduction starter? They seem to spin a lot faster than the big old non-geared reduction type It's not exactly a huge engine it's trying to crank ... I'd have thought a weeny little ride on mower starter would be adequate
    May 2013
    171
    still has to be turning over quicker than using the crank handle
    BTW why is it called a crank handle, because you get cranky when you use it???
    Peter
    1950 11BL
    1970 AZUA "La Poste" van
    1986 2CV Dolly (red and white)
    2004 C5 HDi silver 2.0L
    Feb 2011
    230
    Who knows what sort of drag is in a 2CV
    with gear driven cam , oil pumps,, my secret oil mixture gone wrong , well below zero , in winter , will try it tomorrow,, actual driving
    My latest thinking is now Penrite with the very high Zinc
