ID19 manual steering
Results 1 to 22 of 22
Like Tree2Likes
  • 1 Post By Rally
  • 1 Post By badabec
Thread: ID19 manual steering
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    350
    Default ID19 manual steering
    I am looking at a good 1966 ID with LHS2 but it's got manual steering. Was wondering is it straightforward to convert to power steering. I can see myself getting hold of a power steering rack, but what else will be required?
    Also makes me think if I'm going to do that, it might be worth switching to LHM and work my way through the whole system seal by seal. Has anyone done that, any advice appreciated.
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    558
    I had an ID19 with manual steering . it was far to heavy for the wife to drive.
    To solve the problem I fitted a LHM power steering rack ,the shorter relay arms , belt driven 5 piston pump and a LHM resivior .
    I left the brakes and suspension running the origional LHS from the cam shaft driven single piston pump
    denxm likes this.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Jul 2013
    Stamford, UK
    350
    Quote Originally Posted by Rally View Post
    That's an interesting way of doing it! A lot quicker than changing all the seals I bet. Did you have to make a different camshaft pulley to drive the pump?
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,405
    Good LHS power steering racks are hard to find. Rally's solution seems the simplest, though you would also need a pressure regulator and main accumulator. You also have to change the steering wheel (smaller diameter, different fitting where it engages rack).
    Roger
    Feb 2012
    Ongar / England
    868
    Hotrodelectric likes this.
    Warrnambool
    2,405
    If you keep the manual steering, having plenty of tread on the front tyres and high pressure in them helps. I had a 1963 ID19 with manual steering for a few years and that was my solution.
    Roger
    Jul 2013
    Stamford, UK
    350
    Roger
    Must admit I find Rally's option pretty encouraging as I've got lots of spare LHM bits already. Thanks for the advice, feel more inclined to give this ID a thorough look over now.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Pearl Beach NSW
    558
    My solution of a LHM steering rack was considered , as I was wrecking a later model DS due to rust,
    Just a matter of swaping all the bits over .
    The second resiviour for the LHM gave the engine bay a unique look.
    Not a hard job to do , finished in a day .
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    16,709
    Take the car for a drive with it's manual steered rack. I don't mind them without power steering. They are nowhere near as bad as the non-power steered CX's.
    If your wifes anything like mine, she probably won't want to drive it anyway
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    Yes not bad as long as i don t go to shop car park or metropolitan area
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
    Jul 2005
    Feilding New Zealand
    41
    they're fairly light as far as armstrong steered old cars go in my opinion!
    As Roger said, good tyres at decent pressure makes a huge difference.
    Melbourne, Victoria.
    1,390
    Quote Originally Posted by badabec View Post
    Great alternative suggestion badabec.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,158
    I Drove a 6H for many years and the wife had no problem steering the car. Waaay heavier than an ID19. The trick is to turn the wheel when the car is slowly rolling. Turning a stationary wheel requires much more effort!
    !D 19s are getting to be rare beasts. It would be a shame to corrupt the original design brief of a simplified DS.
    Cheers Gerry
    Fellow Frogger! Middlemoon.1's Avatar
    Jan 2011
    Alphington
    859
    I loved the steering on my ID. If the correct tyres are well-inflated, front end is properly lubed and maintained, it is crisp, positive and responsive. The big white wheel is a fabulous and distinctive feature. Reverse-parking is greatly assisted by the car's geometry and broad front track. Heavy steering on an unknown car could be down to a variety of things that might not be normal.
    Tim
    Jul 2013
    Stamford, UK
    350
    Think I'd better go and have a drive in it then. Stopping the wife driving it could be an incentive!
    I noticed its got what look like XAS tyres on the front and Michelin X tyres on the rear. Is that correct, I'd always thought XAS were on the 5 stud wheels and that earlier D's should have X's all round?
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Jan 2011
    Alphington
    859
    Hi, I'm guessing that the 66 would have the five stud with the later tyre. But there are interesting transition cars around this time in Australia at least. This would definitely be all around. The Michelin X tyre is on the single stud wheels. Let's face it, if you've got a chance to get a decent ID, grab it!
    11,220
    Quote Originally Posted by marc61 View Post
    My Renault 16 experience suggests high tyre pressures, the narrowest tread you are allowed and new tyres was the best for steering weight.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    castlemaine
    503
    I seem to recall that when I replaced the ancient Michelin X on my ID19 with new ones the steering was transformed. Stopped squealing too. Only time when the steering effort was really noticeable was in multi-story car parks, and as the long wheelbase is not suited to such venues I learnt to stay away.
    roger
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    571
    In my experience replacing old tyres with new on a DS also reduces the steering effort.
    cheers Tony
    Feb 2003
    Hobart Tasmania
    72
    I drove a 1961 Citroen 1D19 for over five years and never felt the need for power steering. However, before that I owned a Citroen Big 6 and that had heavy steering. Currently I own a 2000 model Citroen Berlingo with over 210,000 km on the clock and the steering in this vehicle is still pin point sharp, light and accurate. (It is power assisted)
    16,709
    I've got one 2 ID19's here ... one with manual steering and one with a powered rack. Both the same vintage, same tires same drivetrain. Your welcome to try them both (the ugly pink one with the power steering drives waaaayyy better). Not due to the power steering, due to the lack of wear in it's mechanical components.
    You buy DS's/ID's not by the specification, but by the amount of rust in them. If it's not rusty, it's the one to buy. specification doesn't matter at all!
    San Diego, California, USA
    3,543
    Not technically correct. The XAS came out in I think '70. However, your car is a '66, so it would be the first of the 380mm wheels, as opposed to 400mm for '65 and before. Your pair of XAS isn't a shock because of fitment, it's more of a surprise because they haven't rotted away yet!!
    Yes, I am aware you can buy (incredibly expensive) reproductions.
