Sorry, one more XM question
Results 1 to 3 of 3
  • 1 Post By citroenut
Thread: Sorry, one more XM question
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default Sorry, one more XM question
    At stop lights, the rear of the car will sometimes rais up but, more often, drop down to the bump stops. About a minute or so later it will raise/lower itself to the correct height. Is this normal and, if not, what could be causing it?
    thanks
    Warren
    11,220
    Quote Originally Posted by WRB View Post
    At stop lights, the rear of the car will sometimes rais up but, more often, drop down to the bump stops. About a minute or so later it will raise/lower itself to the correct height. Is this normal and, if not, what could be causing it? thanks Warren
    Never apologise for another question!
    Forgot to add, my Xantia has always done much the same. If you leave the pedal pressed, that is, and release after a while. All to do with brakes driven from rear suspension spheres and height corrector behaviour I suppose.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Coffs Harbour, NSW, Australia
    626
    Assuming that there is nothing mechanically wrong, the trailing arm rear suspension reacts to braking by trying to lower the rear of the car. Therefore if you keep your foot on the brakes after you've stopped ,the car senses it is too low & tries to correct. When you remove your foot off the brake pedal the rear will rise higher than it should & of course the car will correct in the opposite direction.
    It is possible to amuse the great unwashed at traffic lights by playing with the brake pedal to achieve a constant oscillation at the rear.
    Provided the rear brakes haven't seized, no Citroen with trailing arm rear suspension will stop with the nose down & tail high in a panic stop like most other cars. Watch a 'D' panic stop & it squats like chook !
    Hop this helps Warren.
    Richard
    UFO likes this.
