D heater tap with thermostat
    Oct 2003
    Hampton Park
    523
    Default D heater tap with thermostat
    What is the thermostat doing in this tap?
    Open or closed when cold/hot?
    Whats it for?
    Sherman
    8,245
    Quote Originally Posted by Sherman View Post
    Whats it for?
    Sherman
    This question has come up before, this answer made the most sense to me. . .
    On the 403 and 404 Sofica heaters the capillary is a temperature control arrangement.
    The flow to the heater is turned off whilst the coolant is under temperature, to help a fast engine warm up.
    I believe the capillary also modulates (open/closes/reduces) the water flow through the heater valve to control the air temperature from the heater.
    08 C5 X7 HDi very Noir
    Kapunda
    493
    I notice that on the D the thermostat is sampling the air temp after the heater and thus is controlling the air temp to the cabin.The coolant flow through the heater does not go to the radiator and thus slows down the engine warm up by the amount of heat transferred to the cabin.
    Oct 2003
    Hampton Park
    523
    Thanks for the information fellows
