Factory BX immobiliser by-pass button question
Results 1 to 9 of 9
  • 1 Post By Ken W
Thread: Factory BX immobiliser by-pass button question
    11,207
    Default Factory BX immobiliser by-pass button question
    Can anyone remember how the factory-fitted immobiliser system works?
    You can get a situation when the car is immobilised and won't go. I recall there is a button in the glovebox that you press while turning the key and then the system is reset and works properly.
    Is there a procedure, such as turning the key on and off a particular number of times, or do you just hold it and the car goes first time?
    There's a car stuck in Perth.....
    Cheers and thanks.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Fellow Frogger! FedGrapes's Avatar
    Aug 2011
    Perth, WA
    838
    Further more, what does the factory immobiliser immobilise? Is it spark, fuel, starter, or a combination?
    I think I know which BX is being spoken of!
    11,207
    Quote Originally Posted by FedGrapes View Post
    In my experience it immobilises the starter, but maybe other things too!
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,044
    You have the procedure correct. You hold the button in the glovebox on and then turn on the ignition and the motor should turn and start. If it is not disabled, I seem to remember that eveything looks OK until you try to start, then everything goes dead on the dash - but it might do this when the engine is cranking anyway - its just more obvious when there is no cranking noise.
    Hope you sort it soon.
    Ken W
    FedGrapes likes this.
    Aug 2011
    Perth, WA
    838
    I think I've solved the problem guys. I'm going to buy a new starter.
    I took a direct feed from the starter solenoid, and connected it to the battery. Nothing. That takes everything out of the equation except the starter itself, so it's time for one with a new solenoid!
    Ken W, according to the wiring diagrams, the dash doesn't get power when the key is switched to the start position. The ignition system retain power, and the starter gets powered.
    I've got to find that button in any case!
    11,207
    Quote Originally Posted by Ken W View Post
    Ken W
    Many thanks Ken. The only time I've needed it, the switch was there, as far as I can recall. Last time I looked for the switch out of interest, I could only find a small socket in the glove box, so presumed the wee plastic button had fallen out and had been lost to history. FedGrapes now owns the car - the switch would have to be at the end of the only wires going to the glove box apart from the light.
    John
    Dec 2010
    Wollongong, NSW
    519
    In my car it would crank over but not have any spark and I never could find the button.
    8,245
    Quote Originally Posted by Erikbm View Post
    On our 16v the override switch was not in the glovebox - not sure if it's appropriate to reveal where it was located on a public forum though . . .
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    16,700
    pretty sure it was behind the glovebox in our old BX ... Strongly suggest removal and throwing away. You don't want the damn thing stranding you somehwere
