c5 bushes
Results 1 to 9 of 9
Thread: c5 bushes
    temora nsw
    163
    Default c5 bushes
    Hi citmen.Could anyone tell me where to buy rear trailing arm bushs for 09c5x7.Im at a loss out here in the bush.Dealers are a ripoff .cheers Tomfrog
    9,331
    Tom X7 c5s don't have trailing arms (see pic) Do you mean the anti-roll bar links?
    (ignore the steel spring in the pic, different model; the link is item 4)
    9,331
    temora nsw
    163
    Must be the longatourdal? link? Mechanics called trailing arms . no wonder Iam confused.76 and silli.tomfroger
    9,331
    I mentioned the roll bar links because you had a roll bar bush problem 3 months ago. Most of these bushes and small items are MUCH cheaper from the UK by mail as you will have noticed. Locally before I went to a dealer I'd contact someone like European Auto Imports (Sydney), Dapco (Sydney), or Caravelle Imports (Melbourne), but it would help if there was a better description, as well as the VIN.
    There was a time when Citroens did have trailing arm suspension, so you can see my confusion, but the C5 X7 is multilink. The longitudinal arm restrains the wheel when you crash into a hole, so that sort of road could wear the mounting early.
    temora nsw
    163
    SEASINK My suspension is the type where the antiroll bar is conected to a link which govens the activator/acumulator.TOMFROG
    9,331
    Heres a pic of the roll bar and height sensor as seen from the back. What bush is needed?
    Here's another overall view from the front
    temora nsw
    163
    Seasink;front view long arms on edge of printout.also upper rear hub bushes. Thanks for your concern.Tomfrog.ps Iwill try and find someone in Griffith over xmas who has a lexia to check settings etc.Merry xmas.
    9,331
    Bushes for the longitudinal arms of the multi-link then. Try the usual suspects as mentioned; if all else fails there is a dealer. Your local mechanic can use the pics to email what is needed if necessary if he doesn't see many Cits.
