SM gearbox, Lotus Esprit Turbo question
Results 1 to 12 of 12
Like Tree4Likes
  • 4 Post By dsvitesse1
Thread: SM gearbox, Lotus Esprit Turbo question
    CitroŽn Tragic UFO's Avatar
    9,784
    Default SM gearbox, Lotus Esprit Turbo question
    I have a work colleague who asked today about how to find info about an SM gearbox. Strange I thought coming from a UK car fan. Anyway, her husband has a Lotus Esprit Turbo and would like to source info on the gearbox because it is the same as the SM 'box.
    I found the link in the manuals thread and pointed her at the combined SM page etc etc.
    Was it the correct assumption of her and her husband's re the gearbox or have they, and now I, been lead up the garden path?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Some ran a Renault transaxle and others a Citroen one. I think the Renault box came out with the more rounded update esprit.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    350
    Think the box is the same, but the differential is the mirror image. On the Merak the differential needs to rotate the other way as engine/gearbox layout is reversed (gearbox behind), else if you put an SM gearbox on the engine you'll get 5 reverse gears and one forward. Assume same applies for Lotus unless their engine rotation is the opposite way?
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    dvr
    dvr is offline
    736
    The Merak and Lotus have the diff flipped.
    All the original Esprits, the G models after the designer Giorgetto Giugiaro, had the Maserati/SM box. From 1987 the rounder later model, the S after it's designer Peter Stephens, initially had the Maser/sm box in the normally aspirated models and the Renault box in the turbos. From about 1988 or 1989 they all had the Renault box.
    Does your colleague's husband need a Lotus box? I have one complete with the inboard brakes etc. Or if it's the later S model turbo with the Renault box I have some of those too.
    Fellow Frogger! pajamas's Avatar
    Jan 2005
    Canberra, ACT
    278
    Asked and answered.
    Paul in Canberra
    1974 DS Safari (aka Sophie Safari)
    1972 SM (aka Simone, aka S'Moan)
    Subaru WRX
    16,693
    Quote Originally Posted by dvr View Post
    Are you sure they only flopped the diff Isn't that the DS gearbox. I thought all the shims and bearings didnt' like running backwards
    That's why it's far from easy to re-power a DS .... you need to reverse the gearbox
    Jan 2011
    netherlands
    45
    Hi
    Lotus Esprit Giugiaro gearbox is the same as SM till 1983. It was know as "previous" Citroen. From 1983 to 1988 they used the so called " C 35 "casing. Some internals were also changed.
    Bellhousing was specific for Lotus. Turbo and non Turbo.
    The Maserati Merak has the same engine as the Citroen SM but in the rear and therefore they needed to convert the rotation of the gearbox. It was completely mirrored. Gearbox casing, bell housing, 5th gear carter and cover. Also internals were mirrored.
    Lotus had the luck, their engine rotates in the correct way, opposite to the Maserati engine,so the SM gearbox was a plug and play unit.
    See photo, left casing is Merak.
    Harry Martens
    Attached Thumbnails Attached Thumbnails SM gearbox, Lotus Esprit Turbo question-img_6441merak.jpg   SM gearbox, Lotus Esprit Turbo question-img_6442merak.jpg
    GreenBlood, dvr, UFO and 1 others like this.
    Don't remind me!
    16,609
    Very neat picture; thank you.
    9,784
    Thanks all for this excellent information, and I don't think there could be any higher authority than Harry. I will forward the link of this post to the colleague.
    Cheers!
    16,693
    All I can say is "Wow" .... talk about an exact mirror image!
    9,784
    They forgot the smear of yellow paint.
    Don't remind me!
    16,609
    If you look carefully the smear of violet paint is there.
