C5 x7 Gear selector difficult to move to drive/reverse
Results 1 to 13 of 13
    South Australia
    69
    Default C5 x7 Gear selector difficult to move to drive/reverse
    Gentley men
    I have over the last couple of days noticed a slight locking/reluctance of the gear selector to select drive or reverse after engine has started, in my preivous C5 04 model there was a fantastic step by step process with photos to replace the offending item, has anybody done the same thing for the X7 ??
    16,693
    There's not a load on the parking pawl is there (eg: the automatic handbrake isn't applying).
    Does the car sort of thump and move on it's wheels slightly when you get it out of park?
    9,325
    Concerning the shift lock, M. Citroen says:
    C5 x7 Gear selector difficult to move to drive/reverse-am6.jpg
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,043
    The park position lock-in system is starting to get a bit sticky in our car. You bump it once or twice and it still releases but I guess I an going to have to have a look at how to lube it up abit sooner rather than later. There is quite a definite positional click between all the other gear staick positions once you have it out of the park position. Does this fit your symptoms?
    Ken W (watching another line of storms approaching Brisbane)
    temora nsw
    163
    Hi Replacement was done on my c5x7 last week/the unlock relay is up behind t he glove box.remove g/box
    for axcess. same relay can be purchaed? cheaply from automan. TOMFROG
    South Australia
    69
    Hi Shane
    No there is no thump or move just difficult to shift into drive etc, but I have found that if you apply pressure downwards that helps, worried about where I will be when it doesn't shift.
    Seasink
    thanks for the info on what "Citroen says" but alas I am unable to understand it, if you were able to translate that would be even better.
    9,325
    The causes of the fault may include the following:
    Battery voltage
    The shift lock
    The gear selector lever position switch
    The automatic gearbox computer
    The wiring harness
    Operations to be carried out:
    Unclip and remove the trim (1)
    Unlock the shift lock using a screwdriver (press (2) in the arrowed direction)
    Move the gear selection lever out of position "P"
    Oct 2014
    Brisbane/Australia
    435
    Not only do we have a flashing check engine light, nonsensical codes and cruise control not working, now the 2010 Cit C5 X7 we have been playing with doesn't come out of P easily after starting the car and putting foot on the brake pedal. It can take 10 attempts. I think this car is cursed.
    North Brisbane
    2,043
    It will start in neutral so forget Park and leave it in Neutral. I am doing that with mine until I can summon the energy to replace the relay that is up behind the glovebox.
    Cheers, Ken
    Oct 2014
    Brisbane/Australia
    435
    Quote Originally Posted by Ken W View Post
    It will start in neutral so forget Park and leave it in Neutral. I am doing that with mine until I can summon the energy to replace the relay that is up behind the glovebox. Cheers, Ken
    Do you happen to know its part number or exactly where it is located? I am not sure why I offered to help with this car.
    9,325
    There was a thread a week or so ago that linked to photos of the relay. Needless to say you will need to be a contortionist and you back will be sore afterwards, unless you have a capable child available..
    You won't need a Citroen part number. It's a standard automotive relay, available at any parts place. Just match the numbers printed at the terminals.
    Clonbinane, Victoria, Australia
    218
    My 2009 is doing the same thing. I thought I'd found a way around it recently as it would move into gear if I tried immediately on starting the car. Worked for about 4 days then went back to how it was before.
    Oct 2014
    Brisbane/Australia
    435
    We are currently using it as Ken suggested, leave it in N. Have ordered a new relay. Will use a supple young adult to change it.
    Sent from my SM-N950F using Tapatalk
