First fault displayed on my c5 x7
Results 1 to 25 of 50
Like Tree5Likes
Thread: First fault displayed on my c5 x7
    St Helens Tasie
    601
    Default First fault displayed on my c5 x7
    Yesterday an "engine management system fault" showed up on the speedo. The car ran fine, no obvious external signs of a problem. Bit of a worry. Trying to think back to previous threads on this forum I tried to narrow down the most likely and simplest cause. So, over the past year there has been a gradual decrease in time I could have the radio on or the internal reading light before "energy economy mode" is activated. Down from 30 mins. to less than 10. I hooked my ( simple) charger up and charged the battery overnight. Started the car in the morning and a beep sounded and the engine symbol went out ( it stayed on when the fault showed up previously). The green light was also on in the battery, hadn't seen that before. No fault showing. A friend took a voltage reading at the battery and it was 12.65v. Assume this is OK? Started the car again and the reading went to 14v. so I assume the alternator is OK.
    I wonder if the reserve power of the battery is now low, after 4years and I need to change it.
    As We looked at the voltmeter we noticed a whirring sound from the motor, like something was not quite in gear
    Is this normal?
    Allan.
    Don't remind me!
    16,609
    Yes, and yes.
    Of course, Shane may swear black and blue it's the fuel filter.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    It is the battery. 4 years old, time to replace
    Motorgnome likes this.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    8,615
    If your car is like mine it is an AGM battery - see eg, Absorbent Glass Mat (AGM) Battery Information - Battery University Expect to pay more.
    Modern chargers have an AGM setting to reduce the float voltage, as per the link. Alas my 50 year old charger doesn't, so it rarely has an outing now. A pity, as any tool that has had its use time must be a quality item.
    The green indicator is a hydrometer built into one of the cells. When it's high you can see the green.
    16,334
    Yes, and yes.
    I have no idea.
    8,615
    Ya got me there with brain out of gear after too much at lunch Robmac. It would indeed be moist in there. Fixed.
    There's a pic of the green dot here - http://www.autozone.com/repairinfo/c...&subtitle=test
    PS I visited Aldi for one of those and none were left. My local is in the midst of a transplanted corner of HK, and there seems to be little call for tools. I find that they are plentiful in shops in the western suburbs, but it's quite a drive. I usually drop into one of those when I'm in the area.
    9,670
    Yes, and yes.
    Blocked electron filter.
    UFO likes this.
    18,772
    Half your luck SS. My lunch was a bowl of Chinese fish ball and noodle soup. Hard to become confused in head after that!
    addo likes this.
    CitroŽn Tragic UFO's Avatar
    9,668
    New battery is what you need. Mine didn't get to the beep moment but was sluggish and "missing" on cold mornings. New battery and all was good again.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,894
    Hi Tassie,
    THere is a thread on here somewhere about how I put a supercharge battery into mine last year. I will try to find and add a link.
    Ken W
    18,772
    Don't be ridiculous! The battery leads aren't long enough to tie in knots.
    St Helens Tasie
    601
    Thank you all. Any battery recommendations?. The Varta batteries are almost double the cost of others.
    8,615
    Check you are comparing like with like. AGMs are more expensive. My car came with a European DIN Exide 70AH 720 A.
    Don't remind me!
    16,609
    I think you can get a Fullriver one, which are actually quite well regarded, for a reasonable sum.
    North Brisbane
    1,894
    I will check the number on my Supercharge one tonight. Autobarn even had one in stock if I remember correctly. The battery is a MF66H and fits pretty well. It even looks like thay have improved the CCA rating to 760 amps now.
    Ken W
    St Helens Tasie
    601
    The car went into limp mode today. I changed the battery ( AC Delco) . I had to set the time etc. The car runs fine now but the fault light is still on and the engine management warning came on.
    To confuse matters, the old battery tests out under a load as being OK. The voltage dropped from 12.6v down to 12.4v after the load test. The amps were also within a new battery parameters. Not sure what to do now. the dealer is a 4 hour round trip away.
    St Helens Tasie
    601
    Hang on!!! After 20 mins. having a rest ( the car that is) the c5 was started the engine fault came on for an instant, a beep was heard and the fault disappeared. It just shows that the French siesta works on their cars also.
    Thanks all for your comments.
    North Brisbane
    1,894
    It sometimes takes a few starts and/or the passing of some time (overnight) for faults that are stuck on to reset themselves.
    Don't forget it could just have needed to have its battery terminals cleaned. New cars are not immune to this sort of fault.
    Ken W
    St Helens Tasie
    601
    Fault back again!!! I have reset it a couple of times and it has disappeared, only to re emerge when a slight bump driven over. The car drives OK without any obvious symptoms. I will disconnect the battery overnight and hope the fault does not re appear when reconnected. We head for Launceston tomorrow (160km) en route to Melbourne so hope I don't do any damage. I may ask the dealer to try to clear the fault while I'm away.
    Any thoughts appreciated.
    Jun 2004
    Mackay
    33
    Tasie,
    You are'nt by any chance driving left foot brake right foot accelerator are you? This used to produce "engine management system faulty" in my 2007 2.2TT until I woke up that my wife never got the problem and realized the cause.
    Regards, rossie.
    St Helens Tasie
    601
    Thanks Rossie.
    I am a right footer for sure. The fault cleared a couple of times after a new battery and also after a disconnect/connect battery procedure. I will know later today after a trip to Launceston if any nasty symptoms occur.
    Allan.
    North Brisbane
    1,894
    Sounds like you might need a code reader at some stage. Thay are very good for pointing you in the right direction.
    Ken W
    St Helens Tasie
    601
    Came back from Melbourne yesterday and picked up the car from the dealer where my son took it whilst I was away. They found some faults had been registered but were unable to determine the error that caused the fault readout as their diagnostic gear went down. Back in St Helens now , the car ran perfectly well. I still don't like the fault showing though. They did detect low voltage, even on the brand new battery. They did charge the battery overnight, and did not charge me for their work. Just wish the fault would resolve itself.
    North Brisbane
    1,894
    Alan,
    If fault persists, maybe the next thing to replace is the engine fusebox. I had one replaced in mine during warranty after a few episodes of all the warning lights coming on and transmission being locked into 3rd gear limp home mode for the rest of the trip.
    Ken W
    St Helens Tasie
    601
    Although The fault light persists, I,m inclined to try to ignore it as the car runs well. It has to carry out a lot of duties in the next month.
    Always at the back of my mind I wonder what will happen. Has the fault been cured by changing the battery? Is a diagnostic tool required to clear the fault that is no longer a problem?. I may try cleaning the MAF, but I am worried that I may introduce more faults.
