Air bag light. Xantia
Results 1 to 13 of 13
    Nov 2014
    ashburton nz
    25
    Default Air bag light. Xantia
    hi
    wonder if any one can help me with air bag light that remains on while driving
    2001 xantia ;or tell me where to look to fix problem;
    I see you can buy diagnostic readers ie OBD2 would this work on
    xantia regards kevie.
    Don't remind me!
    16,609
    It can be in several places. The crimps to the small plugs under the front seats, the "clockspring" in the steering hub (easily damaged by those not careful enough), in the airbag connector plug itself (just ahead of gearstick) or (uncommon) in the connections to the passenger airbag.
    Faulconbridge
    2,364
    Mine also comes on occasionally whilst driving. The light that now stays on is the injection light;no difference in performance and according to Lexia is due to "intermittent +ve" whatever that means ????
    Don't remind me!
    16,609
    It means a slightly shaky power supply to the injection computer. Anything from a battery terminal to a faulty alternator or stretched wires in the harness.
    Faulconbridge
    2,364
    Thanks;next question,how do I unstretch the wires in question,Andy.
    Don't remind me!
    16,609
    Replace! If the harness was pulled on during a clutch job or similar, tack in a wire that is parallel.
    Nov 2014
    ashburton nz
    25
    hi thanks for your help will check this and post results /do front seats have to
    come out to check wiring.
    Don't remind me!
    16,609
    No, you unclip the small black plastic "board" from the springs underneath.
    Lexia is the better diagnostic tool, if you have a spare laptop it is worth getting.
    Nov 2014
    ashburton nz
    25
    hi again yes problem was with wires under passenger seat /light has gone out
    thanks for your help.
    10,705
    Quote Originally Posted by KEVIE View Post
    That's great news. What exactly WAS the problem with the wires please?
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Don't remind me!
    16,609
    What it usually is, people don't quite "get".
    The crimping of the connector terminals onto the pretensioner trigger wires is marginal to poor. People blame the connector itself, in error - and claim they fixed the problem by removal of the connector and direct joining of the wires with soldering.
    In fact, if you open the plug out (a couple of seconds with a small prying tool) you can remove the wire/terminals and soft solder where it's crimped. After reassembly of the plug, there is no trace of the repair, and you can remove the seat without any cutting of wires.
    9,670
    The connector for the brake switch that is part of the brake pedal is another one to check.
    How is your Big 15 project Kevie? I'm assuming you are the same Kevie and that the discussions of that car were unfortunately lost in our crash of 2006-2010 material.
    Nov 2014
    ashburton nz
    25
    hi yes that's me ;no longer have big 15 still have 51 light 15 and xantia
    will post pics when I work out how.
