DS Coil Ballast Resistor & Thermal Overload Switch
Results 1 to 3 of 3
    May 2012
    Newport/Vic/Australia
    15
    Default DS Coil Ballast Resistor & Thermal Overload Switch
    Does anyone know where I can obtain a new or second hand ballast resistor that attaches to the coil for my '74 DS23 EFI and also the small thermal overload switch that sits on the battery carrier (for the air horns I think)
    Garry
    Mar 2011
    Broom
    819
    you can certainly find the ballast resistor at Repco. From memory a new coil and ballast resistor is about $50.
    Symar/ca/usa
    607
    Quote Originally Posted by Garryds23 View Post
    Garry
    Why not just replace with a more modern internally resisted coil? Cheaper, better (typically provide about 50% more spark voltage). Not sure what an EFI requires for minimum resistance as we (NA) never got them. But a 123 or Pertronix equipped car needs at least 1 ohm.
    Steve
