Am about to put a new resister board in my xm series 1 because the transistors were worn.
Was thinking of doing the well known zantia series 1 mod being a relay at the ignition to ease the load.
Question is.. is the xm wiring-plugs the same as the zantia,i pulled the ignition out years ago and replaced it with new barrel and harness because the barrel was getting worn and did not want a no go problem later.
I will be home in a few days then will remove covers to check wiring and also re-install fan.
thanks ..denxm
