AL4 Oil - Confusing
Results 1 to 11 of 11
  • 1 Post By seasink
Thread: AL4 Oil - Confusing
    Fellow Frogger! Inspector Clouseau's Avatar
    Dec 2002
    North Coast NSW
    188
    Default AL4 Oil - Confusing
    I'm wanting to change the oil in my Xantia AL4 auto transmission and have been advised by a knowledgable AFer to beware of choosing the wrong oil. Consequently I've consulted Dr Google and come up with a lot of opinions, the majority being Esso LT 71141 ATF as the way to go. Found an old AF thread on the topic that added to my confusion and got a bit narky to boot. Esso is available in Victoria but is very expensive and will require freighting as well. My question is: when a brand like Penrite or Nulon claims its oil meets LT 71141 specs (e.g. Penrite full synthetic) does that equate to it being at least as good as the original Esso LT 71141? Or would I be better off with the expensive older Esso variety?
    Thanks for any advice
    Feb 2002
    Coolum Beach
    1,876
    DS Un jour, DS toujours !
    8,594
    I'll add to the confusion. Here's a Sydney supplier of American Redline that claims equivalence. Mobil Oil, Redline Oil, Shell Oil, Royal Purple Oil, Pennzoil Oil,Dust-Off, Plasti Dip!. Royal Purple on the same site claims equivalence as well.
    Onshore Oil in Brisbane has Total Fluide AT Long Life, also claims to be suitable. http://www.onshoreoils.com.au/upload...%20LIFE_PS.pdf
    jaahn likes this.
    Don't remind me!
    16,609
    LT71141 is still readily available in NSW, in 20L "cubes".
    tweed heads
    1,483
    Family owned elf distributor in bris 0439660295
    Newcastle
    2,572
    Hi Inspector,
    I did own a C5 auto and have also a VW Transporter auto, which is an associated transmission which uses the same oil. I bought a 20 ltr drum of the LT71141 oil from my local Esso distributer several years ago at a reasonable price. I used this for oil changes for both but it ran out
    So being now convinced that the oil is not the problem with these transmissions and that that oil is now a very ordinary specification and not worth paying through the nose for, or not even worth driving further to get, I changed to a full synthetic Multi use type. Penrite in fact. A reasonable price and guess what ? the world did not come to a halt, the sun came up the next day, and the transmissions worked as good or even smoother than before !!! No problems since then. A friend has done the same with his Pug also.
    The problems with these transmissions are not caused by the oil, per say, it is the lack of oil changes, and faulty valves. Perhaps other faults also in some rarer instances. Nothing new there ! These problems are made worse by a dealer network who KNOW NOTHING ABOUT CARS AND CUSTOMERS generally. If you do your own oil changes and stay clear of the dealers your chances will be much improved IMHO.
    jaahn
    Feb 2011
    brisbane Au
    927
    As long as it's always readily available and conforms to LT71141 I use Penrite ATF full synthetic. Citroen doesn't have the monopoly on the AL4.
    Feb 2011
    brisbane Au
    927
    Well said jaahn. Stay way clear of dealers at all costs. Notice how Penrite is red?. Listen to a dealer rant when his numbered forehead serviceman discovers the red oil, my god it's better than the second coming. No blasphemy intended there, but wait until he's finished and, then tell him it's Penrite. The silence be deafening. Cheers Tony.
    Dec 2002
    North Coast NSW
    188
    Thanks all - really appreciate your responses. I feel more relaxed now and have a few viable options.
    Oct 2013
    Epping
    108
    You should use Elf
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,657
    Another vote for Penrite FS. My Renault DPO is perfectly happy on this diet.
