C5 Auto problems AL4
Results 1 to 18 of 18
Like Tree4Likes
  • 1 Post By shanadoo
  • 2 Post By bluey504
  • 1 Post By moulton2speed
Thread: C5 Auto problems AL4
    Jan 2011
    Red hill,vic
    29
    Default C5 Auto problems AL4
    Hi All
    I have had my C5 2004 HDi automatic re-conditioned by a european automatic specialist with disappointing results.
    It has been back 3 times they have replaced the solenoids about 3 times and finally installed a extra large oil cooler, which has not improved the auto from intermittently going into limp mode and slipping and thumping when driven in peak hour traffic.
    They have reconditioned a number of these and are scratching their heads on how to fix mine.
    I heard there was an upgrade for these with larger oil galleries.
    Any ideas out there.
    Please help
    8,592
    Could the problem be outside the gearbox completely? Eg, diesel "throttle" position being sent correctly?
    Newcastle
    2,572
    Hi snooze,
    Not good ! However could you give any information off any diagnostic interrogations ? Probably need a bit more information to make any suggestions.
    Jaahn
    Feb 2011
    brisbane Au
    927
    Hi snooze,
    "It has been back 3 times they have replaced the solenoids about 3 times and finally installed a extra large oil cooler, I heard there was an upgrade for these with larger oil galleries".
    Your gearbox should have been already fitted with the larger oil cooler, so seems strange they replaced it yet again, I say again because they would/should have replaced the cooler when they did the overhaul. Unless they wasted your money and used an aftermarket remote unit. The upgrade "Larger galleries" would have been done by the factory before your C5 vintage.
    Sounds like they're guessing. Get a Lexia download by someone who can read the damn codes properly. Cheers.
    Jun 2002
    hervey bay qld
    13
    I'll try again. 1st post disappeared
    Citroen made el cheapo gearboxes - the AL4
    You need to buy a replacement box (made in SA I believe) as I had to when mine had all these problems every moans about.
    The new box will have brass bushes, not the carbon fibre crap used by Citroen.
    Cost about $5k.
    Mine was fixed by Brisbane Citroen
    No more worries
    Will last forever
    David
    david
    pillsnpotions
    Mar 2005
    855
    David, Slight correction here. The AL4 is a German made SIEMENS unit. It is equally problematic ( or not ) for other brands as well.
    My current C5 has a Mitsubishi starter, a VALEO alternator and the HDi diesel system is a SIEMENS product. Some door seals are by Metzeler ... some have Bosch brakes, some use TEVES ..... truly an international product. Citroen have not had a good run with the bought in automatics ... BW35s in DSs , some of the ZFs in various Citroens are either swear by or swear AT varieties...even the supposedly 6 speed from Aisin Warner isn't without its problems..again valve/solenoid related.... Maybe Citroen and now PSA buy cheap ?
    8,592
    Why stop with that list - I've a list of suppliers for the current C4 - an international gathering whose most common tongue is definitely German. There's even Japanese and Americans there.
    10,703
    Quote Originally Posted by fritzelhund View Post
    I doubt they buy cheap really. I suspect those devices all behave the same way but people are reluctant to admit a problem with them fitted into a "reliable" brand and "everyone knows French cars are unreliable". I won't go on...
    Bad luck Snooze and hope it sorts itself fairly quickly. I'm with Jaahn's advice myself.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by bradbury View Post
    Cost about $5k.
    No more worries
    Will last forever
    David
    jaahn likes this.
    Feb 2011
    brisbane Au
    927
    European Union stuff. Except my C5 has a big Aussie nut behind the steering wheel.
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,249
    Quote Originally Posted by shanadoo View Post
    So your surname is Macadamia?
    Brendan.
    shanadoo and jaahn like this.
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by bluey504 View Post
    Brendan.
    Could be, but the parents called me Goaway.
    Mar 2005
    855
    Apart from "failure to proceed " situations I wonder how many problems are due to perception issues. A case in point. The 4 speed INVECS in my old Mitsubishi is supposedly able to learn driving style...I can never notice any change in its shift patterns, and while it has only 4 forward ratios to choose from, it is always right. The 6 speed in my C5 also is supposed to learn the drivers style and I suppose it does, but it also seems to respond quicker after a bout of manual over ride. I wonder about the newest generation 8/9 speed stuff ( as in Jeep )that must have friction surfaces/valves that are smaller to fit twice as many bits into the same overall gearbox size, and the chances that with 8 ratios they will make/select the correct decision only 50% of the time over a 4 speeder. The lock up able on 3rd and 4th on BXs seemed to cause some driver learning or experience .. and the non slip locked up converter on my old Camry was set too low at 60 k/p h. Are the damn things too complicated for their own good, all in the search for minimal at best fuel savings ?? The Americans came up with very reliable simple autos in the 60s. Things seem to have gone backwards. Is this the driver towards CVTs ???
    Dec 2010
    Wagga Wagga
    342
    I want to stick up for the BW35 in the DS23 efi. A very reliable unit and gave us no trouble in 230k km in our ownership. The only problem I knew of was as seals hardened oil could exchange between the separate diff and gearbox. Not in our 24 years.
    Using the correct auto transmission and diff oils was important.
    frenchtranstech likes this.
    Oct 2013
    Epping
    108
    Siemens only make the electronic component.
    Oct 2013
    Epping
    108
    Great words
    agree totally
    i was involved so much in all those units throughout the 80s and 90s
    Oct 2013
    Epping
    108
    Those factory bushes came out on the last of the Al4s, Bushes are actually bronze coated
    Sonnax U S A have bush kits that can be used on overhaul.
    Sep 2003
    North Parramatta
    3,988
    AFAIK, the AL4 (and all its iterations, like AT8, EAT8, DPO, etc.) are made in Valenciennes (in France) and in China.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
