Towbar wiring
Thread: Towbar wiring
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    510
    Default Towbar wiring
    Can someone recommend UK/Aussie supplier for Canbus/multiplexing tow bar electronics (electronic relays)
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    Don't remind me!
    16,609
    The French suppliers seem to have the best "faisceaux spťcifiques" but the buggers won't send overseas. If you remain stuck, I could ask a CitroŽn acquaintance in Charente, if he'd assist.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    633
    Default towbar wiring
    Hi Don i just put one of these into the picasso does the same trick as the thing i made for your old C5
    7 WAY Smart Bypass Relay Towbar Towing Electrics Canbus Relay | eBay
    510
    Quote Originally Posted by Balki View Post
    Thanks Addo and Balki - seems like most cars (German, Ford, GM) are using multiplexing these days - that is why there is a market for a universal application.
    Don't remind me!
    16,609
    The issue with the "smart" relays is not massive, all that happens is you need to actively disable the reverse sensors when towing, and also the rear fogs - if they come on before the fronts may be used - won't be disabled.
