sphere removal tips?
Results 1 to 25 of 43
Like Tree3Likes
Thread: sphere removal tips?
    Fellow Frogger! brycedunn's Avatar
    Jun 2012
    165
    Default sphere removal tips?
    Hello all,
    I am currently trying to remove the spheres from my DS so I can take them to the CCCNSW tech day tomorrow. My bright idea was that it would easier to remove them in my own garage where I have access to everything I need and just bring them with me in a box to the tech day.
    The only problem is that something that would appear to be so simple is being anything but. After two hours I only have one off! (passengers front).
    Are there any tips that can be offered?
    Bryce
    1954 Light 15
    1970 DS21 BVH
    http://www.classicjalopy.com
    8,257
    Quote Originally Posted by brycedunn View Post
    Hello all,
    Bryce
    Bryce,
    This is my procedure, car on jack stands, crack the spheres to be removed with your strap tool, just enough to break the seal!
    De-pressurise the system, set car to low and open the blead on the pressure regulator, just a quarter turn. Have an absorbent clean rag around the base of the sphere to catch the flow of LHM.
    Spheres should now just spin off.
    Don't try to remove the rears without following this technique, you need to break the seal whilst pressurised or you can damage the high pressure line.
    08 C5 X7 HDi very Noir
    Jun 2012
    165
    Cheers chris.
    The trick with the rears worked a treat.
    I had to go and buy a beefier strap wrench as I broke the first one. Second one required a meter long breaker bar to crack the spheres, but they did in the end.
    Bryce
    1954 Light 15
    1970 DS21 BVH
    Jun 2012
    165
    These spheres did not want to come out, that is for sure!
    1954 Light 15
    1970 DS21 BVH
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,236
    Hi Bryce
    when I screw my spheres back on, I have only ever tightened them up snug by hand.. hardly anything. I make sure the seal lines up properly. They never leak and I can remove them with a simple twist later, by hand, when the system is depressurised.
    Matthew
    Jun 2012
    165
    Quote Originally Posted by mnm View Post
    Hi Bryce
    Matthew
    Good tip. This is the first time I've had them off the car after having owned the car about two years, so I wonder if the previous owner or his mechanic used a strap wrench to tighten them?
    Bryce
    1954 Light 15
    1970 DS21 BVH
    San Diego, California, USA
    3,543
    Couple of things, Bryce: remember which are front and which are rear. The shock absorbers are different, and are gassed to different pressures. Also, I know its a pain to get at, but you may want to take the main accumulator sphere as well and have it checked, unless of course you've already had that done recently.
    Jun 2012
    165
    Thanks Hotrodelectric,
    can't see it in the photos but I have marked the slots in the box so each one can go back where it came from.
    i did want to remove the accumulator as I have a short cycle time and given my accumulator is a disposable type, I have bought a new one. I found some instructions on how to remove the sphere without the whole assembly, but I couldn't get that to work, so I guess I will need to remove the whole assembly.
    1954 Light 15
    1970 DS21 BVH
    8,257
    Icon12
    The disposable accumulator spheres are a little deeper and can present some difficulty, you may need to jack the motor up, use a plank under the sump to spread the load.
    Make sure the car is very secure on stands and even pack a couple of the removed wheels under the body before you climb under!!!!
    If you are at all unsure, removing the whole assembly from above is the safer option. Also gives you a chance to clean and paint the regulator
    3,543
    Yah, that space really wasn't designed for the pineapple spheres. As you noted, they fit, but they don't fit. If you finally do remove the regulator, remember line seals. Sometimes you can reuse them, but usually not. They're cheap, so just buy some. I forget what size they are- 6mm? Someone will know... Chris?
    Symar/ca/usa
    607
    Bryce
    Bryce,
    Doubt it - Sphere's are steel, cylinders are Al. Over time and especially at the rear (exposed to the elements) AlOx (Al Oxide) forms between the cylinder threads and those of the sphere. That is the major cause of the binding. The second cause is mechanical binding just from the force those threads are subjected to during the normal use of the car.
    With the front the other thing that happens is not all pressure can be released, even with the car on stands. If the front spheres are not 'rockable' - IOW you cannot wiggle them a bit by hand, you have residual pressure in the system. Easiest way to solve is to lift the passenger side wheel ( in you case) with a jack just to the point of where that side of the car starts to come off the stand and then lower.
    When you reinstall the units put a smear of LHM compatible grease on the sphere threads - will go a long way in helping to remove later.
    As to identification - DS fronts rebuildable spheres should have a "59" stamped on the top of the filler cap - the rears should have "26". Refers to bars of pressure inside ( 1 bar = 14.5 psi).
    Steve
    Jun 2012
    165
    Spheres were tested today and pressures were good. Before attempting to remove the whole assembly for the accumulator, I have roped in an 'assistant' for Tuesday to take one last crack at it.
    Bryce
    1954 Light 15
    1970 DS21 BVH
    mnm
    mnm is offline
    Dec 2010
    3,236
    I have a 2-piece accumulator sphere, engine on "new" mounts...I tried removing it from underneath a while back but there was no way it was coming out the bottom. So is it only removable from the top?
    Matthew
    16,748
    Matthew
    that should come out ... Is it an accumulator or a suspension sphere with the valve unscrewed
    mnm
    mnm is offline
    Dec 2010
    3,236
    It's an accumulator sphere..
    8,257
    Matthew
    Definitely removable from below, what was the hindrance? You may still have to jack the motor a little to clear the crossmember, but with a 2 piece sphere there should be clearance?
    16,748
    It might pay to check the engine height. With the squat two piece accumulator it should clear.... Well it has for me the few times I've removed them either way
    mnm
    mnm is offline
    Dec 2010
    3,236
    It seemed it wouldn't fit through any opening forward or rear of the crossmember. Is it supposed to exit to the rear?
    Matthew
    Don't remind me!
    16,609
    If it's in Economy, most likely.
    I'm presuming this faffing about for accumulator removal, relates also to IDs.
    8,257
    Matthew
    Unscrew and remove to the rear Matthew, I have to use the jack under the sump to gain clearance as I currently have a welded sphere which is probably 20mm deeper than your 2 piece jobby (about the depth of the thread). I would think if your engine is sitting at the correct height you should be able to simply unscrew and remove?
    8,257
    Just about everything is easier on the older IDs, at the very least you can better see what you are doing . . .
    It should be pointed out here that with the more up-specced later cars (Pallas) the accumulator/regulator is positioned for ease of access up in front of the radiator. Some enthusiasts have made this modification on their lowly models.
    16,748
    That really only happens on the LHD cars ................ They have the steering column in the way too. From underneath there shouldn't be too much of a difference, no matter how crowded the engine compartment is from above (well that's my theory either way ... and I"m sticking to it!).
    8,257
    Icon3
    No, RHD Shane, my 23iE (manual converted from auto) had the accumulator/regulator out the front. Might have been something to do with it having been an auto as they have an oil cooler where the regulator normally sits
    3,543
    How was that done, Chris? Attached to the transmission or the frame? I'm imagining the lines were all-steel into the regulator.
    I know that for quite a while it was popular here to relocate the regulator off-block to somewhere 'accessible'. Long ago, one of the better Citroen gurus here (Scott Curtiss) created a kit that included flexible high pressure lines. Not a horrible idea, except that sometimes introduced more problems than it solved. I mean, have you ever seen a regulator attached to the front crossmember with zip-ties? That wasn't Curtiss' doing, that was just some lazy so-and-so.
    8,257
    Icon3
    It's been too long Bill, I struggle to remember the important things like eating these days
    Harrison is our man, he owns a late auto and should be able to confirm (I think we have narrowed down the change to 23 Automatics) no bodge job though, properly mounted and made changing an accumulator sphere a 5 minute job.
    Where are you Phil??
