Gear shift lockup.
    temora nsw
    163
    Default Gear shift lockup.
    Hi citmen.I have a gear shift which wont unlock untill I touch brake pedal six or seven times .How do rectify this problem ? Car is a 09C5 cit. Could this system be deactived as we travel in regonal areas.Thanks TOMFROG
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,076
    Sounds like your brake light switch down there on the brake lever has almost stopped working. You will find that your brakelights are also not working much of the time either. I think fitting a new switch should fix the problem. On mine I can hear the solenoid on the gearshift lock click the first time I put my foot on the brake. Either that or the solenoid has gone sticky but I have read that the brake light switch fails more often. Perhaps you could get someone to observe operation of the brake lights as you try to get it out of Park as that might help narrow down the problem.
    Ken W
    Ken W
    9,258
    Gear shift lockup.-c5_gearleverrelease_manualrelease_sml.jpgGear shift lockup.-c5shiftlock.jpg
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Switch in the brake pedal needs replacing. I had same issue on Xantia a few years ago.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Feb 2013
    456
    Leave it in neutral when you stop until you get it fixed?
    10,188
ID:	61572Click image for larger version.
    This is an X7 series C5. First image is from a 2001 model, so it's going to be a little different and I don't know if that part number for the detent pin is good for post 2007/8 models or not. The common problems with the earlier X7 cars are either the brake switch or the mini relay that operates the release. If the brake switch test mentioned above shows the lights come on every time, then suspect the relay, which is hidden nearby in the centre console. You may even be able to open it and clean the contacts. You can probably find the brake switch via eBay, but the relay may be a little harder. Matt in parts at Continentals will know these parts if you want a dealer contact.
