Early berlingo man oil in coolent
    tweed heads
    1,544
    Default Early berlingo man oil in coolent
    This is my bro,s car 1.4 litre manuel has no sliding door on side ,he has just discovered oil in the radiator,dousnt appear to have an inter cooler behind oil filter ,could it be a head gasket problem ,it seems to be running just fine, any ideas pugs ps no coolent in oil
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    The headline attracted me: Early Berlingo Man! I thought we'd discovered a new species of human!
    Don't remind me!
    16,609
    Common as muck, this problem. Easy to fix.
    tweed heads
    1,544
    Im all ears addo ,i couldnt find anything on a search ,we all need to know, so please share the knowledge, pugs
    Don't remind me!
    16,609
    Do the head gasket with bolts, use a Chinese set and add a better quality rocker cover gasket. A quick head skim if you're feeling wealthy or just use a gasket stripper. Try to separate the exhaust manifold from the head, rather than from the down pipe.
    DON'T whizz the deck with a Scotchbrite wheel. DO use a double coat of Blue Hylomar spray, applying the second coat once the first has tacked off.
    Replace the top hose and thermostat, the rubber parts of each will be damaged by the oil. You might want to fit a half decent new radiator cap or at least cut it a new hard rubber gasket.
    tweed heads
    1,544
    Thanks heaps for that ,keep you posted, pugs
