GS Diveshafts.
Thread: GS Diveshafts.
    Jan 2011
    adelaide
    154
    Default GS Diveshafts.
    Just removed the driveshafts from the GS Wagon to replace the boots, LHS driveshaft is physically narrower (diameter) , Is this normal? RHS approx. 24mm., LHS approx. 22mm. Would it be advisable to change LHS to a shaft the same Diameter as the RHS. 1220 motor. Mike.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Has someone mixed up 1015 and 1220 driveshafts?
    Cheers Gerry
    Jan 2011
    adelaide
    154
    To me it looks like it as car has had a lot of fiddling with, it is registered as a '74 but I believe it to be a '73. Engine has been changed at some point.
    Fellow Frogger! andrewj's Avatar
    Margate
    395
    Quote Originally Posted by tazzy View Post
    The larger shaft could be GSA? Does it scrape on the top suspension arm for big bumps?
    If you do look for a new shaft, be-sure to count the number of splines as there are two different types.
    Andrew
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    Jan 2011
    adelaide
    154
    Will be replacing the wheel hub assembly off of my GS spares car along with the driveshaft from that car so all should be good regarding spline numbers. No Andrew there is no scraping on the top suspension arm thank you for your input. was just a little suprised to see the difference.
