CX trivial question
Results 1 to 13 of 13
Like Tree2Likes
Thread: CX trivial question
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default CX trivial question
    Does the centre consul ashtray have a light in it? I recall a nice green light Or was I imagining this from another car?
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,247
    Which version are you asking about? Is it the slide out, on top of the radio version?
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    The early version with the vertical radio mount does it is a bulb and holder that slides into the plastic clip on the high edge of the ashtray aperture!
    Cheers Gerry
    Jan 2011
    749
    Mine is series 1 1985
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Mine has the same centre console. There is no light in the ashtray, but there should be a light surrounding the lighter.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Jan 2011
    749
    That there is and works.
    However, damn Poltergeist in my electrics is determined to have something not working!
    I replaced the control light above the ignition key hole happy with that achievement I have put every back together, which is not easy when all the plastic bits are so badly aligned and flimsy, and now the stereo has no power and the hand brake warning lamp is playing up again. Just as well i have many spare hours to chase the Poltergeist.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    Jan 2011
    749
    Poltergeist was hiding behind the stereo, everything is working again but not sure where it will turn up next.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    11,290
    Quote Originally Posted by IE23 View Post
    Don't mess with the Poltergeist! Minor problem? Leave it! Significant problem? Move in gently, don't use bad language whatever you do.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Feb 2013
    456
    Don't ignore it! I had a dash fire recently. The loom running back to the fan speed controller was jammed up against the gearbox housing surround (very sharp edges) luckily switched off fan & smoke stopped. Molten mess later; Pulling out centre console it was evident I was probably the first to remove it since the factory install. Luckily I had just purchased one of those cheap right angle screw driver Rachet sets from the bargain shops so didn't have to remove the drivers seat. (A handy investment if for nothing else)
    11,290
    Quote Originally Posted by Jinandfonic View Post
    Ouch. Perhaps I ought to stand corrected! It isn't uncommon to have something that doesn't work - what was the first symptom of serious trouble to come with hindsight?
    Fellow Frogger! John P's Avatar
    Somerville, Victoria
    153
    Does that mean you found the ashtray light? There is definitely one fitted to your model.
    I agree with your comments on the wiring and the centre console. The plastic embrittles with age, just to make things worse.
    2006 C5 2.0 HDI estate - daily driver
    1981 2CV - The Amelie project is complete.
    1930 C6F torpedo - My Great Folly! Project under way.
    16,743
    Just check you have power and earth .... it's probably lost the earth connection (it's mounted into plastic so won't pick it up through the housing).
    They seem to illuminate better if you use LED's .... Though the LED's seem less reliable than the standard globes in my experiance.
    shane L.
    Member Sturla's Avatar
    Nov 2005
    Bergen, Norway
    73
    Yes, a warning on the led - I am sure there are good quality leds on the market - be sure you get those. I changed all my dash lights to led some months back to a BAD batch apparently, and now it is all blinking and fading out like a really sloppy x-mas decoration. I will be sure to use the traditional bulbs next time round, better with less light than none.
    -74 DS23 bvh, -78 CXgti, -85 CXgtiT1
