DS Window Winder Handle
Results 1 to 15 of 15
    Fellow Frogger! Errol_S's Avatar
    Jul 2014
    Devon. UK
    122
    Default DS Window Winder Handle
    Greetings
    Is there a way to remove the Bakelite handle from the window winder in order to facilitate re-chroming?
    Errol
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    Repro window winder handles are available.
    Via the aussiefrogs App
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    Ici.
    2,667
    Z+3=canteloupe!
    A stab in the dark suggestion might entail considering how they're fitted.
    Is it a plug on the back of the handle (facing the door side!) that then exposes the knob with a screw to hold it to the frame of the handle?
    I'd be looking at prying that off with something small flat and looking like a screwdriver. Gently.
    Buying repros will not get them separated.
    Last edited by forumnoreason; 26th September 2014 at 09:38 PM. Reason: spelling :(
    Jul 2014
    Devon. UK
    122
    I will first try to unscrew, and if not successful then prying off. I will experiment on the worst condition handle in the knowledge that it can be replaced with a repro. I will post the results.
    Ici.
    2,667
    someone put them on there so QED someone can take them off! This has been my broad experience with all things Citroen. However clutch thrust bearings do not generally fit into this category as I found out after thinking- 'this is a bad idea' when someone graciously offered to dismantle mine. I should have punched the *#%+ for even suggesting it!
    Jul 2014
    Devon. UK
    122
    Yep I think we have all been "there" at some stage or other. At times I feel quite guilty with the things I say about the French.
    Ici.
    2,667
    damn the French man! It's the reprobate moron Territorians that are at fault!
    10,187
    Quote Originally Posted by Boyracer View Post
    window crank, chromed for DS 12/72>
    The originals seem to be one of those pot metal special brews and can pit. I suspect you would be hard pressed to dismantle and rechrome them satisfactorily for a lot less than the cost of the repro items. 29 Euro each before you remove the VAT from the price, being a non-EU buyer. There could be slightly less costly sources.
    I guess someone would have to cut up a scrap handle to be sure of how it's assembled. I don't think the knob simply unscrews though. More likely pressed together. Even then, the hole in the end of the handle wears and the knob becomes loose.
    Ici.
    2,667
    have you looked at Prismatic powder coating as an alternative to rechroming? I think despite my troppo flippancy David your suggestion is far more feasible given the cost to replate!
    Kapunda
    494
    This is one of those strange cases where the item on the D Spec is superior to the DS.The D Spec winder is stainless.The same applies to the flat outside door handles.
    Woody
    Citroën Tragic UFO's Avatar
    9,807
    Quote Originally Posted by brian woodcock View Post
    Woody
    It depends on the year of manufacture. Some D Specs have the s/s covered external door handles - and I say covered as they are plastic internals IIRC.
    If the original poster trying to figure how to get a "normal" D inner window winder off the shaft? If so, then push against the door card around the handle base to compress a spring that is behind the handle and door card. Then you will see a pin that is pushed through holes in the handle base. You need to then gently push this through using a suitable drift or even the long end of a thin Allen key. The handle will then easily come off. Replacement is the reverse method. Ensure you get the handle alignment correct so that it clears the passenger knee when the window is fully closed or open.
    10,187
    There are two types of flat external handles, yes. The original version is the die-cast type, same as the GS, although the actual latch is a bit different. They pit badly and if you overtighten the nuts, you leave a dimple where the stud pulls the metal inwards. For the last year or so of production, they changed to the plastic handle with a pressed stainless cover. The early one has parallel sides, where the later (presumably cheaper) ones are slightly angled.
    The pressed stainless window winder handles are for earlier ID and DS with the raised outside handles are they not? I'm sure in my assortment of spares, I have two types of pressed metal handles.
    Boot hinges are not all the same either. There is the obvious difference of plated for Pallas (and Slough) and polished alloy for the rest, but there are also a few different castings when you compare them in detail. The early and late cars also have a different thread pitch, so, there is a small trap when creating a mongrel.
    Jul 2014
    Devon. UK
    122
    Getting the winder off the door is not the issue here. Getting the bacalite handle off the winder is. I must concede defeat because I think damage will be the ultimate result. I will wait until I have a replacement before pursuing this any further, unless someone has a tried and tested methodology.
    8,257
    Icon3 It can be done. . .
    Quote Originally Posted by Errol_S View Post
    This lad appears to have a solution? No indication how the knob separates or how they are reassembled, or if in fact the same original knobs can be reused?
    Specialist in chrome and polishing DS parts
    Chrom
    Attached Thumbnails Attached Thumbnails DS Window Winder Handle-window-winders.jpg
    08 C5 X7 HDi very Noir
    Ici.
    2,667
    Yes this is a teaser now! Who knows the answer?
