D parts location
    geelong
    71
    Default D parts location
    Hi ,need help with those two D-special parts. I cant figure out where they belong. I guess silver guards are going somewhere under front engine bay ?
    Ici.
    2,667
    the aluminium bits sit under your front suspension covers, ie at the bottom of the chassis, they should have a spongey spacer there too to suck up the gunk, the other bit looks like a heat shield for the right engine mount, sits over the height nut and under the lug on the engine mount bracket.- on the block with three bolts.
    geelong
    71
    thanks
    Ici.
    2,667
    the heat shield also has an upper lip and lower as you see, hopefully it isn't too bent out of shape! the lower bit sits towards the motor if I remember! should know I put one in position the other day. My excuse is its getting hot here again, going bangwa, Yolgnu for clazy.
    no the upper lip is on inside because the outside edges of the rubber in mount are exposed to the manifold so the outside of the little shield faces down. Get it?
    geelong
    71
    yes I did found some pictures in manual showing lower side next to manifold.
