DS door contact switch wiring
Results 1 to 9 of 9
Like Tree3Likes
Thread: DS door contact switch wiring
    Fellow Frogger! brycedunn's Avatar
    Jun 2012
    165
    Default DS door contact switch wiring
    Hello All,
    I've had a rather catastrophic failure of the switch that interrupts the current for the interior light when the door is closed. I've purchased a new switch, but I can't get to the wiring to plug it in from that tiny hole in the lower A pillar. I've looked behind from in the interior, from above where the bonnet hinge is etc, but I can't find where I can get my fingers in here to fix it. Any tips would be greatly appreciated.
    Bryce
    1954 Light 15
    1970 DS21 BVH
    http://www.classicjalopy.com
    San Diego, California, USA
    3,543
    Quote Originally Posted by brycedunn View Post
    Hello All,
    Bryce
    Hi Bryce:
    Disconnect the battery, then use a small hook, like a dental tool and try to fish the wire out that way. The shaft will need to be fairly long. Maybe fashion one out of bailing wire or a coat hanger.
    The only way you are going to get your fingers in there is to pull the dash and the air box. There is a hole on the inside sheetmetal, right at the shelf for the dash, behind and below the air box. The wire snakes through the pillar to the switch.
    Jun 2012
    165
    Thanks Hotrodelectric,
    I had hoped there was an easier inspection panel, but since there isn't, I will just have to keep trying to fish them out.
    Bryce
    1954 Light 15
    1970 DS21 BVH
    Los Angeles, CA USA
    1,955
    It can be done! Sometimes you can find the cabin side of the wire and jiggle it enough to give you a visual through that 12mm hole where the switch goes.
    Doing the Daffyduck dance via the AussieFrogs app. With a cane! gimp quack quack ow ow ow.
    Ici.
    2,667
    how about a flexi magnetic parts pick up tool? that might do it with incessant wriggling?
    they're VERY useful little tools and cheap.
    8,257
    Hi Bryce:
    I think most of us have been caught out allowing the wires to drop back into that hole. My technique has been to use two pieces of wire, one with a right angle bend about 25mm from the end and the other a U shaped hook. Insert the right angle wire into the hole and fish around (the good news is the two wires are usually joined if you pick up one you have the other at the same time) once hooked the U shaped wire can be inserted to draw the wires out.
    08 C5 X7 HDi very Noir
    Jun 2012
    165
    Thanks for all the replies.
    With a dentists pick and a set of small tweezers from the cosmetic section of the local supermarket, wires are located and installed on the new switch!
    20140914_115130 by Bryce Dunn, on Flickr
    1954 Light 15
    1970 DS21 BVH
    3,543
    Yay! Like a lot of work on a D- fiddly, but not difficult.
    Jun 2012
    165
    Also replaced my cracked shift surround..
    1954 Light 15
    1970 DS21 BVH
