rear end bang
Results 1 to 12 of 12
Like Tree3Likes
Thread: rear end bang
    temora nsw
    163
    Default rear end bang
    Hi citmen 09c5 has problem in rear end after after falling into pot hole or exiting from gutter.Sounds like metal recoil from torsion bar. any advice? Thanks Tomfrog
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,517
    Sorry, I can't help you with diagnosing the car's problem.
    I was just intrigued by the thread title and thought it related to your Saturday night "entertainment".
    John
    San Diego, California, USA
    3,543
    Quote Originally Posted by tomfrog View Post
    I would be taking that to an alignment shop ASAP and having it checked out.
    I'm not going to bother with the joke. John has that covered.
    temora nsw
    163
    at the age of 75 i am not into rear end banging, [front end?] tomfrog
    Don't remind me!
    16,609
    Can't get Richard to put it on the hoist? If you get the hoist legs correctly positioned under the sills, while it's running you'll need to set the suspension to lowest position and use a jack, bit of wood or a long prybar to slowly force the wheels up and purge the hydraulic fluid. This will allow you maximum "slip" for examining the rear suspension.
    9,276
    No torsion bar, as it's hydraulics, but the rear multi-link looks like this
    While you have it lifted, check out the roll bar and electric handbrake, both in the same area.
    10,192
    Inspect ASAP, but a loose or damaged roll bar mount can make a lot of noise.
    Be sure that the electric handbrake is disabled if anyone takes the pads out or disconnects the cables. If it operates and it's internals are damaged when it over-runs, you will likely have a bill for a few thousand to replace it.
    temora nsw
    163
    thanks citmen .I will look at roll bar.Tomfrog
    Don't remind me!
    16,609
    Irrelevant to Tom's problem, but that version of the C5 rear end looks like the struts would "donate" well to some other vehicles.
    temora nsw
    163
    All is well.Problem solved.Rollbar bush at rear end fractured allowing bar to move and bang about Thanks Citmen Tomfrog,
    3,543
    9,276
    It must have been a hell of a whack to do that, unless the bush was already damaged. Glad it was a simple fix.
