Cleaning / storing a petrol tank
Like Tree2Likes
Thread: Cleaning / storing a petrol tank
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,250
    Default Cleaning / storing a petrol tank
    Little muck seemed to come out of the tank I removed from the spares GS, but as I can't easily get to the recipient vehicle I'm probably going to have to store the tank for a few months and I don't want any corrosion that might be there to spread.
    What should I be using to clean out the tank, and what precautions should I take to store it?
    The paint has lifted off the external surface of much of the tank and there's some surface rust, what's the best approach to fix?
    Via the aussiefrogs App
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    Ici.
    2,667
    KBS do a good metal cleaner/ rust proofer and sealant kit, auto paint shop should have,
    http://www.kbs-coatings.com.au/produ...nk-sealer-kit/
    cheaper than POR 15, and Australian made, follow instructions, a strip disk on a drill or grinder or wire brush attachment on drill for external and zinc primer or just etch primer round outside edges, assuming thats where it is corroding. same with outside areas, clean and rust convert with product.
    The sealant will plug any holes, reminds me I better do the sealant on mine! Cleaned and rust proofed but been sitting for awhile now.
    ps if there's any stale fuel in tank wear a mask in well ventilated area, that shit is TOXIC.
    I'm not sure KBS is Australian made, their staff photo shows only nine people! think you'd need more than that to mix up can and sell this stuff!
    yes , to thread link below I chucked some gravel in mine ( I forgot I did this! and swished it with the metal cleaner, definitely helped. Hot water is imperative with the metal cleaner, you can use it again so have another container ready to pour it into.
    Newcastle
    2,803
    Hi my tip would be to put some diesel inside, swirl it around and plug it up. Then get some large garbage bags and spray it with diesel or WD and 'bagit' and seal 'em up with tape. That will protect it till you are ready to use it and the diesel will have helped to penetrate the dirt and rust for easier removal then.
    Jaahn
    It's how I roll...Brisbane
    33,963
    Hi Bruce,
    This thread surfaced a few months ago and probably isn't what you're looking for but it might be useful to others with fuel tank issues.
    Dirty ideas..
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
