light 15 spark plugs
    geelong
    71
    Default light 15 spark plugs
    Hi,
    what is the correct spark plugs for light 15 available in Aus.
    cheers
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Champion H8. Plenty available on EBAY
    Cheers Gerry
    geelong
    71
    Thanks Gerry
    geelong
    71
    In crossreference as an alternative spark plug come up NGK B6L.
    Also somewhere is mentioned NGK B7HS.
    Should I stick with H8?
    3,166
    NGK are good if the dimensions and heat range are the same go for it!
    Cheers Gerry
