85 CX25 TRI - speedometer dropped out
Results 1 to 3 of 3
    Apr 2014
    Virginia, USA
    14
    Default 85 CX25 TRI - speedometer dropped out
    Does this non cruise-equipped car have an electronic or cable speedo? Barrel type gauge. It went up to 200kph then dropped back to 0, I reset the trip at a stop, stopped a few more times, it started working again and has been fine since.
    CitroŽn Tragic UFO's Avatar
    9,807
    Cable speedo. The cable may need repair as the plastic square end on the speedo end of the cable loses its grip on the rotating shaft causing symptoms similar to your desciption.
    Apr 2014
    Virginia, USA
    14
    Thank you, I'll inspect both ends. Put another 30 miles on the car today, it worked fine.
