XM front Wipers
Thread: XM front Wipers
    Don't remind me!
    16,609
    Icon7 XM front Wipers
    - Do they give a double wipe when you flick the stalk down?
    If so, does it become problematic and want to randomly operate when you turn the car on or off sometimes?
    Fellow Frogger! denxm's Avatar
    uki aust
    451
    addo, i just went and checked mine,only one wipe when i hit the stalk,did not matter if motor was running or not or motor turned off halfway through the wipe.
    Don't remind me!
    16,609
    Thanks; looks to be a 605 only part then.
    Armidale
    2,599
    Every time the 605 wipers are turned off they give a last, defiant wipe. Doesn't matter what setting you have used.
    So when you push down to trigger a single wipe, it does the single wipe, then because it wants to show who's boss, it gives a "turning off" wipe. Even if you turn the ignition off after the first wipe, it will insist on finishing the sequence when switched back on.
    Not having a problem with wipers running "randomly", but the blinker can will sometimes click furiously after the blinkers are cancelled. The son's Xantia wagon did this - turned out to be a worn blinker control arm. No doubt it will turn out to be same issue in the 605, as shifting the blinker arm slightly usually fixes it (until next time ). Might be worth a look at the wiper control arm? Might be some wear causing erratic behaviour...
    Alec
