Lexia diagnostic tool
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    510
    Default Lexia diagnostic tool
    An acquaintance and I purchased a Chinese Lexia/Diag box a couple of years' ago which is a disaster to install and to use. Cost was $340 which I consider is a reasonable outlay. Has anyone purchased a recent version which is easy to install and to use. I guess we only need the software as the plug-in device is somewhat universal.
    From memory our Diagbox is version 6.0 if that means anything.
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    9,292
    Tried here? http://tinyurl.com/krn5bz2 for the iso.
    There's also the odd torrent, and Usenet, though the latter are old posts, so long retention will be needed.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Mine is on an old laptop with the XP operating system. Nothing else on the laptop and so, it works fine.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,523
    Does it recognise at 1995 Xantia VSX? My friends Lexia doesn't recognise it, either via the VIN or typing in year/model. I think 1995 was the changeover from the older BX system to the newer Lexia friendly system.
    John
    Don't remind me!
    16,609
    Quite a lot of cars like yours, have problems with the 30 pin diagnostic adapter in the Chinese kit. I personally believe the simplest approach overall, is to wire in a 16 pin plug like on a later Xantia.
    JBN
    JBN is offline
    8,523
    My electrical skills are such that I would probably completely stuff it up.
    When I had trouble with the idling of the Xantia, we ended up replacing most of the components and cleaning the injectors. It worked. Maybe only one component needed changing and maybe that could have been picked up by Lexia and end up being a bit cheaper.
    John
