New BX Spheres
Results 1 to 7 of 7
Thread: New BX Spheres
    Fellow Frogger! gsmack's Avatar
    130
    Default New BX Spheres
    Hi All
    I thought I might give my BX a christmas present.
    Now that Mel is gone, any ideas where I can get spheres for a bx in melb or outside of melb with not ridiculous postage?
    G
    Dec 2011
    123
    I got some from EAI, but I think they only had the fronts for my 16V so YMMV.
    '92 BX 16Valve (Bathurst 12 Hr edition)
    '93 BX 16Valve (Bathurst 12 Hr edition)
    '01 406 Coupe 3.0L V6 Manual
    16,426
    Quote Originally Posted by LeRob View Post
    If your a member of the CCCV you can get the spheres regassed for a modest fee.
    If you must have new ... try the usuals. ie: Dave Cavanagh, AEI... etc... The melbourne based guys. You can collect that way and not pay postage.
    It sounds like a lot of places are out of stock. If you can't find stock locally, next step is ebay uk ( support the local guys if you can though, if no-one buys from them, they'll dissappear and we'll have no-one then).
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    G,
    If you want to give it a long lasting present, get some Xantia SX front spheres for the front and a Xantia front centre hydractive sphere for the accumulator. The original spheres from Citroen are double membrane spheres and they don't lose any pressure for 10 -20 years so don't need regassing every 2-3 years.
    My BX TZi loved this combo until the lack of ABS, poor driving attentiveness and the back of a Hilux brought it to a premature end.
    Ken W
    130
    Hi Ken
    Thanks for that info. Mum has been searching for that for years. Full spheres were down to bottom third of the range, and it had been exactly 2 yrs since last TLC, so go me.
    By the way for those wondering what had happened to Hekas, he is still in the same old spot.
    Ken, bugger about that Hilux!
    Nowra, NSW, Australia
    234
    Quote Originally Posted by Ken W View Post
    G,
    Ken W
    How does the valving in the Xantia spheres compare to the BX valving though? I have a BX estate with "standard" BX spheres and these a very different to the BX16v spheres on the BX16v. This is not solely due to the different pressures.
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    Although I can't find the table I usually refer to, this will give you an idea:
    http://www.citroenthai.org/info/spherespec.html
    Suspensionspheres:
    Front. Rear
    GS400/55/1.80400/35/1.10
    DS700/59/1.65700/26/1.65
    BX14 & early 16/19400/55/1.80400/40/1.10
    BX Hatch 16/19 P & D500/55/1.80400/40/1.10
    BX GTi hatch 400/55/1.40400/40/1.10
    BX 16v hatch400/45/1.25400/30/0.70
    BX hatch, TD400/55/1.65400/40/1.10
    BX Estate, early400/55/1.80500/40/1.10
    BX Estate 16/19,P & D500/55/1.65500/40/1.10
    BX Estate, TD400/55/1.40500/40/1.00
    BX Estate,TZI400/55/1.40500/40/1.10
    CX saloon, exc Turbo P500/75/1.90500/40/1.25
    CX saloon Turbo P500/75/1.65500/40/1.25
    CX Estate & Safari500/75/1.90700/35/1.50
    XM Hatch 2.0P & 2.1D + Hydract.400/55/0.70400/30/0.50
    XM Hatch V6 & 2.1TD + Hydract.400/50/0.60400/30/0.50
    XM Estate all + Hydract.400/50/0.60400/40/0.70
    XM Hatch Hydract. centre sphere500/70/-400/50/-
    XM Estate Hydract. centre sphere 500/70/-500/40/-
    Xantia 16,18,19D non-Hydract400/70/1.65400/40/1.10
    Xantia 20i,19TD non-Hydract400/55/1.50400/30/1.00
    Xantia 20i, 19TD, 16v, + Hydract400/50/0.60400/30/0.50
    Xantia Hydract. centre sphere500/70/-400/50/-
    400/55/1.8 = sphere volume/pressure in bar/damper orifice size
    The volume of the spheres has a significant effect - the 500cc spheres give a very plush ride compared to the 400cc ones.
    The higher the pressure the softer the springing.
    The orifice size indicates the low speed damping effect (a smaller orifice gives a stiffer ride), but no information is given about the shims comprising the high speed damping effect.
