What's this switch in 69 ID 19 ?
Results 1 to 11 of 11
    Sep 2012
    Somewhere near Mudgee, NSW
    329
    Default What's this switch in 69 ID 19 ?
    Hi All
    What is the switch, rectangle press button same shape as the fan switch. The symbol indicates a left arrow and a right arrow and it is a rocker type ?
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    hi
    This switch turns your parking lights front and back to either the left or the right side of the car used when parked on French country roads not compulsory in Australia
    Kurrajong
    25
    For Europe. When connected turns on parking lamps for either left or righthand side as indicated by arrows on the rocker switch.
    Sep 2012
    329
    Really, what's the thinking behind this function vs all parking lights on?
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    563
    Quote Originally Posted by Big Frog View Post
    preserves battery?
    Feb 2011
    Gosford
    48
    This function was for vehicles left parked on the street at dark in most European countries. Depending on which side they were parked ie parked on the left side -right side park lights were illuminated, parked on the right side - left side lights were illuminated.
    This was at the time a legal requirement of the time. Hope this clarifies things
    Andrew
    Feb 2012
    Ongar / England
    832
    Hello, I thought it was the hazard warning light switch, although on mine its the 'cloaking device' and the switch is broken in the 'on' position.
    Guildford West
    359
    Quote Originally Posted by DS/ID View Post
    Andrew
    Spot on Andrew modern cars are now equipped with good rear light reflectors and streets are well lit so this feature is no longer required. actually this feature was fitted in the earlier Citroen and later replaced with hazard lights.
    And it's that simple
    Sep 2012
    329
    Thanks for the clarification of the switch use everyone. So I'm guessing that a car here that has that feature was a private import?
    Guildford West
    359
    I don't think so! nothing to do with import I would say governed by dash accessories for the ťpoque in question.
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    I had a 70/s BMW 3.0 that had this feature. When turned off with right indicator on ,the right parking lights were on and vice versa . Also 80/s Mercs had something similar .Having rear reflectors doesn't always help because in Europe people park on either side of the road ,sometimes facing on coming traffic [especially in UK]
