CX parts - Drivers window
Results 1 to 11 of 11
    South West Sydney, NSW
    240
    Default CX parts - Drivers window
    Hey Froggy folk,
    Just wondering if someone out there can assist.
    i purchased a GTi from Melbourne back in June and am trying to sort out a couple of issues.
    My main problem is the driver's window. Motor is stuffed, but someone has also fiddle with the window assembly.
    It's been recommended to replace the lot. Does anyone know a good place to start to source these bits? Anyone have wreck that I could cannibalise? "Yvette" is an 85 CX25 GTi Manual.
    Andrew
    16,426
    I've never heard of a motor dying, does it work if you hotwire it straight from the battery Either way if you post up a piccie of the motor, I'm sure I'll have one that's the same here somewhere.
    Sydney, Australia
    124
    Hi Andrew,
    I have some window motor assemblies which I guess have come out of 2400's. (Surely Citroen didn't redesign the assembly between the 2400 & 2500 models !).
    I'm also in Sydney (inner west).
    PM me if interested.
    Glenn
    16,426
    Quote Originally Posted by gembee View Post
    Hi Andrew,
    Glenn
    His will probably be the later type ..... we'll see. I think I have two different types here at least.
    San Diego, California, USA
    3,534
    Just a suggestion, Andrew: you might want to talk at CX Basis. What is your driver window is their passenger window. What I'm getting at is comparable wear. The passenger side is less likely to be worn than the driver side.
    BTW, the 85 is the last of the Series 1.5 cars with the chrome bumpers.
    16,426
    I've got stacks of those motors here ... If it is actually dead (the early ones brake there housings ... I've never heard of one electrically dying) .... I can send one up .... I have enough spares to last about 50 lifetimes I still need to know what sort it is (ie: piccie)
    Member tinfoilstar's Avatar
    Apr 2013
    Pretoria, South Africa
    49
    I recently aquurex a cx 2400 1981/82 model that was an export to SA. Right hand dtive. Chrome bumps all right. Windows work but make terrible noises!! I havnt starred opening up anything yet.
    Im sure to follow tips and learn from ur experience.
    The external mirrors are nor original. Remote adjystment obviously stuffed. Any spare mirrors around?
    3,534
    Got ya, Shane. My thought was more along the lines of the winder mech. A break in the housing? Yah, I'd say that qualifies as a stuffed motor.
    Fellow Frogger! Rob T's Avatar
    Oct 2002
    133
    CX2400 and CX2500 window winder mechanisms are different in detail. They sort of look the same, but they are not interchangeable. The doors also have the mechanism mounting holes in different places. So you will need replacement parts from a 2500.
    As Shane says, I've never seen one that has failed completely. The usual electrical problem is broken wires in the loom where it passes thru the door hinge area. The window winder switches also get dirty contacts. A pressure pack of electrical contact cleaner will usually fix the switch.
    The mechanical parts of the mechanism would benefit from cleaning and adjusting. The nylon slides do wear a bit and the grease gets old and dries out.
    Robert Thorne
    Citroenless - for now...
    Member twistedeez's Avatar
    Mar 2011
    Byron Bay
    114
    I put an 86 Bx window moter in Andy's 76 Cx wagon and it works a treat.
    Out of the 1992 Saab 900 turbo and into
    1989 Citroen Bx 16v
    240
    Thank you all for the feedback and offers of assistance. Quite a few distraction so including being made redundant.
    I finally bit the bullet and took the car out to European Automotive who sorted the window, drivers door lock and the blue slip.
    Gti is now registered in NSW!
    Thanks again.
    Andrew
