DS Door Glass
Results 1 to 25 of 26
Like Tree4Likes
Thread: DS Door Glass
    Kapunda
    457
    Default DS Door Glass
    I have broken the Drivers Door Glass on my D spec!! After a quick search I have found 3 LHS ones.While I notice there area few subtle differences (Asymmetries) I cannot see any insuperable problems. Has anyone tried this.
    Woody
    Don't remind me!
    16,609
    Do you have DS door glass in it already?
    I would have thought a DSpécial might carry ID spec door glass.
    Ici.
    2,560
    This would be the fake glass?
    Kapunda
    457
    This is a 1975 D Spec, the glass is the same as a DS21!
    Woody
    691
    Hi Brian,
    They are interchangable, just the etched writing in the corner may be reversed.
    You will need to take the metal strip off the bottom of the drivers glass and put it on the bottom of the passenger glass - note the lateral position on the glass.
    Both 4mm and 5mm glass was used in the cars, I don't know when, but measure the other windows to be sure you getting the same.
    If your going to that trouble I'd also put some new slides in (they are available overseas easily) to tighten the mechanism up. I just did this and the windows are like new...!
    I've never pulled the metal strip off one myself so can't help there.
    Mark...
    PS. I'm sure a wider search would yield the correct drivers glass from someone - it is one of those things that is not needed that often. It will save you messing with the strip...
    San Diego, California, USA
    3,534
    Different years/different trim specs. The only 'fake' glass was the rear hatch windows on the wagons- they were using plexiglass (except in the US) because the hatch was already so heavy. Fun fact: that was why nobody (except in the US) ever saw a rear defroster on their wagon.
    addo likes this.
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    All D Safaris in NZ had glass in the rear hatches. Most of the late ones had demisters, but none worked for very long!
    8,185
    Quote Originally Posted by Mungous View Post
    In Aus the very early Safari used plexiglass in the rear. My '67 had no rear demister but a glass rear screen, my later '72 Safari certainly had the demister in the glass.
    Brian,
    As mentioned by ds21bvh you can use the door glass RH to LH by carefully prising the metal channel off the bottom and refitting the glass using the channel from the other side, you will mirror the manufactures etched marking. If you are going to fit new slides and I highly recommend you do, be aware they are available in 4 and 5mm to suit the glass you are using. I have my glass removed at the moment and several slides were cracked or broken so new replacements are ready for assembly.
    08 C5 X7 HDi very Noir
    3,534
    Brian,
    Learn something new every day. I was given to understand we were the only ones who got glass rear hatches. Apparently not.
    Member onlyfrogcars's Avatar
    Oct 2005
    Near Heathrow, LONDON
    30
    Not all
    Early French assembled RHD cars had the plexiglass rear, and I'm told that Slough ones may have had glass.
    Kris
    castlemaine
    503
    I have successfully done this ie fitted a RHF glass to a LHF door. It was on a early D though. I seem to recall that a fair amount of care was needed to prise the metal channel off the glass and recover the rubber. Refitting was also a careful process and success depended on the condition of the rubber.
    roger
    Kapunda
    457
    Thanks for all the helpful advice.I was hoping that someone would tell me to just wack it in as it is!!
    Woody
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,346
    You had me confused for a while there with the term LHS. I was wondering how a door glass could be hydraulic. Hydraulic powered windows, cool idea!
    Roger
    Don't remind me!
    16,609
    Wasn't it proposed for the Dee?
    8,185
    A few things were dropped, another was hydraulic wipers. . .
    1000+ Posts michaelr's Avatar
    1,393
    And hydraulic air brake! Imagine if all the possibilities had been fitted, there would be no need for the DS rust prevention thread, but keeping up a supply of LHM for all those leaks would have been impossible
    http://www.citroenet.org.uk/miscella...raulics-2.html
    GreenBlood and Mungous like this.
    Michael
    Member, Citroen Car Club NSW
    3,534
    Roger
    For that, you need something like a '48 Lincoln Continental or a Mercedes 600 Grosser. **SNAP** goes Mme Guillotine's idea...
    Jinandfonic likes this.
    Kapunda
    457
    The Austin A90 Atlantic also had hydraulic windows,how about getting back to the subject!
    Woody
    9,777
    Quote Originally Posted by brian woodcock View Post
    Woody
    Well, it won't work. Hope all you like, but the steel rails at the base of the glass differ from left to right. Discussion about plastic Safari 'glass' and hydraulic window regulators don't alter the relevant answers already provided.
    Make sure you know how to adjust the glass before closing the door with it wound right up. Otherwise, you will looking for yet another pane of glass.
    Don't remind me!
    16,609
    Did the factory centre their door glass with temporary spacers on the edges? That seems to me, one way of getting it right.
    My OSF glass is perilously close to the B pillar trim, the A post is damaged and the door doesn't hang right - the OP might need to adjust the door first, then the glass...
    16,426
    I like the idea of hydraulic windows .... as the car sinks slowly down to the ground so would all the windows ......... It sure would make starting the car exciting ... "who will the windows grab when I start the car this time"
    Kapunda
    457
    I am pleased to announce that I have successfully fitted a LHS door glass complete with steel channel to the RHS door.It was not all plain sailing,I had to grind a bit off the channel,but it is now all working well.This procedure may well offend some purists ,but now its all together none can tell!
    Woody
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    Nice one. A positive outcome is a positive outcome!
    Via the aussiefrogs App
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    9,777
    OK, fair enough. I was wrong as you've made it fit.
    Do the two bolts at the bottom still act as stops when closed.
    Did you slide the channels up or down so the glass can't catch on the roof?
    Feb 2013
    451
    What a fun hypothetical project, Would this motor work? http://www.ebay.com/itm/2-5-cu-in-WH...item3f33c86771
    A separate accumulator sphere for windows, wipers, locks & seat operation. The car would never rust again!
