Gs brake caliper seal kit in Melbourne.
Results 1 to 10 of 10
    Jul 2003
    317
    Default Gs brake caliper seal kit in Melbourne.
    Hi legends,
    I'm in a bit of a hurry to get some gs 1220 brake caliper seals, I only need one side but will purchase a full set if required.
    Thanks,
    Harley
    Sent via the future...
    Greensborough, Victoria
    359
    French Connection Airport West would be worth a call
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    372
    Quote Originally Posted by J'aime la vie View Post
    Harley - if my memory serves me correctly, was at French Connection recently and they had a packet of GS brake caliper seals (about 6) but not the smaller seals.
    Attached Thumbnails Attached Thumbnails Gs brake caliper seal kit in Melbourne.-2013-05-26-12.51.27.jpg   Gs brake caliper seal kit in Melbourne.-2013-05-26-12.51.41.jpg
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    9,777
    Front or rear caliper? I assume they are different.
    Do you know the part numbers and/or dimensions of the seal needed?
    Should be in the parts list, which I don't have.
    Oct 2005
    vic
    848
    Jul 2003
    317
    Thanks guys,
    I did call french connection before posting on here and was told they didn't have any.
    Harley
    Mar 2003
    356
    Hi. I have 2 NOS Citroen 'joint's part no. 5 435 906 in original packaging, which I was told are for GS calipers. I don't know if for front or rear. They are about 50 0r 51mm O D.
    Don
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    Jul 2003
    317
    Thanks Don.
    I am currently hurtling north in the slipstream of a road train
    I will drop some verniers on the spare pistons when I return, eta 18th August l.
    Harley
    May 2012
    393
    Hi Don+Harley, according to the GS parts manual, this part 9 435 906 is a dust proofing seal for the front brakes. There is an inner seal 5 435 950 that is the actual seal. It is slightly smaller. Please see page from manual below.
    I imagine a seals kit would have both.
    Cheers leconte
    1962 Heidelberg ID19 "Axel"
    1965 Heidelberg ID19
    half owner 1974 GS 1220 Convertisseur Break
    Mar 2003
    356
    Quote Originally Posted by Leconte View Post
    Cheers leconte
    Thanks, Leconte. So these bits are not what you need. If they are of any use to you I am happy to post them.
    Don
