2CV6 Brakes Design
Results 1 to 16 of 16
  • 1 Post By Renburg
Thread: 2CV6 Brakes Design
    Feb 2011
    230
    Default 2CV6 Brakes Design
    I was reading the Haynes, and its not clear
    Is the 2CV system a split diagonal system
    Or a split front to rear system
    Or does a brake line failure result in failure on all 4 wheels
    Los Angeles, CA USA
    1,955
    Split.
    Front to rear.
    No side to side. No diagonal.
    16,426
    front/rear by the looks of it.... so in theory if the front fails, you should be able to stop on the rear before pumping the reseviour empty.
    Feb 2011
    230
    Thanks,, that is good to know that it has some redundancy , I have driven with a rusty disk on one car long time ago ,
    never again , I spend the money these days , I dont care for myself , but wife a sons are different
    Feb 2011
    230
    I will check my rears are working by doing a hard stop then feeling the heat in the rear drums ,,,, if any
    It may be that both cylinders are jammed and only the front disks are working , its just that it doesn't stop like a modern car so I am slightly worried
    16,426
    You want a car that's designed almost 70years ago to stop like a modern car You can't be serious
    Disc brake front, drum rear, weighs bugger all, it should pull up quite well.
    shane L.
    Feb 2011
    230
    I mainly just want to check the rears are actually working, I have an idea Will jack the rear up and put a 3 foot bar on the rear wheel studs and get my son to put his foot on the brake just to check the torque on the rear wheel
    There is nothing wrong with a common sense check , except that nobody seems to do it
    jaahn likes this.
    16,426
    Quote Originally Posted by Renburg View Post
    You need to look at the circuit diagram. Often french cars have a limiting valve on the rear axle. If you take the weight off the rear axle with a jack, you will get no pressure to the rear brakes.
    Do you have a 2cv manual there?
    shane L.
    Los Angeles, CA USA
    1,955
    Climb under there and listen while a helper pumps the pedal. Oftentimes you can hear the shoes move. Had one like that about 10 days ago.
    Doing the Daffyduck dance via the AussieFrogs app. With a cane! gimp quack quack ow ow ow.
    Feb 2011
    230
    Thanks for the replies , yes I have a Haynes, Shane
    and thanks for the tip ,
    I will check it when the wife comes home and report
    Feb 2011
    230
    Report , works fine with a big breaker bar on the rear wheel nuts , plenty of grab , will put new disks
    on the front then I can drive like JBN
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,238
    You don't need brakes to drive like me.
    Just keep the right pedal down and aim for the empty spaces.
    If you don't have a good relationship with God, twiddle the wheel as appropriate. Utter the name of the Son of God when you scare yourself. Use any good Aussie expletive when another driver scares you.
    John
    Feb 2011
    230
    Got the tappets done , centre muffler on the way , looking at my adaptor that adapts a larger Z158 oil filter onto the engine, looks about double the stock filter size , and Im tempted to give some panel beating apprentices my guards , if I could find them , the apprentices that is
    JBN
    JBN is offline
    8,238
    Remind them how thin the metal is so they don't stretch it in their enthusiasm.
    I know an apprecntice hairdresser for when you need the hood to be replaced.
    John
    16,426
    John
    The front guards are the easiest panels to repair as they have some rigidity too them and lots of "crown" too the metal... The bloody doors are near impossible (ever so slightly crowned, so very difficult to work). The rear gaurds usually get bend aroudn the bottom edge, so loose all there strength (from memory we welded braces to the bottom edge of the rear guards on my mothers 2cv).
    Feb 2011
    230
    Default Thanks
    Lots of good knowledge here
    I put a block of semi hard foam and wood under my seat , in effect almost zero cushioning
    I feel like Im sitting up like Jackie
    And will be ejected out of the window easily
    My eyes are just below the top level of the windscreen
    It feels good try it
