Start Ya Bastard
Results 1 to 10 of 10
  • 1 Post By Hotrodelectric
Thread: Start Ya Bastard
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default Start Ya Bastard
    Maybe the Nulon product should come with a warning;
    ...could cause a backfire and Explode Ya Engine!
    this is precisely what happened on the Donor CX. I was trying to start her up cos I have to move her soon, but she was being reluctant, so sprayed some 'Start Ya Bastard' into the air filter box then crank crank crank BANG!! Preignition inside the air intake plenum, which shot the plenum forward separating at the rubber joints. I put the plenum back but now she sounds even less enthusiastic about firing up.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    San Diego, California, USA
    3,543
    Quote Originally Posted by IE23 View Post
    Getting any fuel at all? The check for spark is easy enough- just remove two of the HT leads, place across yer nipples, and crank. You'll know soon enough if you're getting spark.
    I forget if your car is EFI or carb. If it's carburetor, try dropping a little fuel directly down the throat of the carb. You could even chase with a short burst of ether. If it's EFI, you should be able to see if the rail is getting fuel. Also, especially if it's EFI, be sure either your battery is charged, or you have a working helper battery. EFI sucks a lot more power than you think.
    Don't remind me!
    16,609
    Icon12
    One place I haunt, it's known as "Seize, Ya C***" after a reluctant Delica turbo diesel finally started on the stuff, then seized thirty seconds later.
    HRE - were you scarred for life by your experiences as a shop boy?
    16,702
    Is the fuel pump running ... Is it out of fuel? The injected ones should fire right up with a decent battery!
    Via the aussiefrogs App
    16,702
    Oh yeah,don't fill the airbox!!! You need to have the engine cranking/sucking too use a starting spray !
    3,543
    Nah. I just learned to appreciate the finer things in life. Repeated 40K volts from an HEI system will do that to you. Talk about making your brown eyes blue....
    Symar/ca/usa
    607
    I thought that only happened when you were only half full....................
    Steve
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,859
    Do you mean that fully tanked is safe?
    Every day is a good day
    Feb 2011
    230
    Yes its not trustworthy in plastic boxes , its OK if everything is metal , ,
    Ive used equal parts of it with kero and Castor oil to start my model diesel engine , the John Deere version is the best if you can get it , its rare
    it has 80% ether , quite a lot
    3,543
    Quote Originally Posted by Citroenfan View Post
    Steve
    Ok. Now it's on like Donkey Kong. Those guys are safe over on that side of the Pacific. You OTOH...
    addo likes this.
