OXY SET >>>> with no bottle rental?? Is no longer a dream in Australia
Results 1 to 20 of 20
  • 1 Post By DoubleChevron
Thread: OXY SET >>>> with no bottle rental?? Is no longer a dream in Australia
    16,415
    Default OXY SET >>>> with no bottle rental?? Is no longer a dream in Australia
    Coregas ? Trade N Go Gas? is So Easy ? Available at Bunnings Warehouse
    I just found this linked on another website. Bunnings do oxy and accetaline where you pay a refundable deposit for the bottles.... no rent! Dsize is plenty for DIY'ers
    dvr likes this.
    Member Duffster's Avatar
    Jun 2014
    South East Melbourne (Keysborough)
    41
    Shane, are they in Melbourne yet?
    19,090
    Unless I've misread the core gas site the facility is only available in NSW.
    I guess they may expand the operation to other states eventually.
    16,415
    No idea, just found it myself.............. Hee,hee BOC sure is going to liek this. They can cram there $180++ a year PER BOTTLE rental where the sun don't shine. If this takes of at bunnings the industry will have to follow or they'll loose 100% of the DIY market.
    16,415
    Bugger! I hadn't noticed that. I reckon it'll be so huge for them, they'll roll it straight out across the other states.
    Oct 2012
    600
    I had a quick look on the Bunnings website but I couldn't find a price on a refill. I moved to oxy-LPG so I didn't have to pay for hire on the Acetylene cylinder, maybe I'll move back as oxy-LPG is a pain to light. Pity they don't have shield gas but I can get a swap type cylinder for this already but without the convenience of Bunnings' opening hours.
    Dec 2010
    canberra
    169
    As usual ACT is irrelevant, not part of Sydney so we don't count. If it ever happens I will certainly be interested, bottle rent is the only reason I have never got an oxy set so far.
    agd123
    9,769
    Oxy-LPG is also not hot enough to weld steel and uses much more oxygen due the different combustion ratios of the fuel gases. LPG is cheaper and good for heating and brazing, but isn't nearly the equal of acetylene. That said, I very much liked my Portacolt kit and it was excellent for cutting car panels etc., but just not up to welding.
    For shielding gases in Sydney you could consider Speedgas in Brookvale. They will sell cylinders (Note Coregas retains ownership) and did offer delivery, but that seems to have stopped. They do not offer oxygen and acetylene.
    If you are a tradie, the convenience of delivery and a huge range of outlets covering all types of gas makes BOC's rental charge a non-event. For the DIY-er with limited use and time on their hands, avoiding paying BOC rental may be worth the hassles. If you change the number of cylinders you hold, pay by the month to avoid being hit with multiples of annual rental fees.
    16,415
    My understanding was it's hot enough to weld and cut with (you need LPG cutting tips). The issue is hydrogen embrittlement if you weld with lpg though
    They had a ripper little dinky lpg/oxy set they demo'd for me last time I was at the BOC store. He said the cutter tips worked quite well too.
    For me to have an Oxy set and Mig welder ... through BOC would be over $600 a year in rental .... Which is absolutely ludicrous for DIY type use..... Even if you don't use them.
    Oct 2012
    600
    You can't fusion weld steel with oxy-lpg but its not so bad for brazing or silver soldering. I use a tig for fusion welding.
    Sent from my C5503 using Tapatalk
    dvr
    dvr is offline
    697
    This is good. I can't do without my oxy set but as a DIY I probably only use one set of bottles a year with my Henrob kit. So saving a few hundred bucks a year will be worth it.
    8,755
    Coregas is the old Linde Gas renamed, and along with Bunnings is owned by Wesfarmers.
    Even though they state that the gas deal is NSW metro only, it's a pretty generous definition of metro - from Port Stephens down to Mittagong and Nowra. That's about a quarter of the country's population. If it works out I would guess Victoria would be next.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    I look forward to this innovative move! I have been unable to afford gas bottles so my oxy set just sits idle now!
    Cheers Gerry
    19,090
    It's also wise to bear in mind that Acetylene must not be transported in a normal boot or passenger compartment.
    Even if the ute has a canopy it must be in a sealed enclosure vented to out side.
    BOC police the transport religiously. I wonder if Bunnings do/ will do the same
    3,067
    The Oxygen bottle is actually more dangerous than the Acetylene.
    Cheers Gerry
    8,755
    Plenty of graphic warnings here - https://www.google.com.au/search?q=p...+gas+explosion Press the images link.
    Jul 2004
    803
    Ho-leeeee. Literally had a similar conversation today after finding the oxy set bottles both being left on.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    castlemaine
    503
    Bottle rental for oxy and acetylene cylinders has always been a pain going back to when CIG had a monopoly on the business. But, if you wanted to be able to gas weld you didn't have much of a choice. I've been oxy/acetylene fusion welding for over 50 years, and it remains my method of choice for rust repairs. I have MIG and TIG welders but I find that, for bodywork, MIG is just too brutal and un-predictable, and TIG may be OK when you can set up on a bench with uber-control but is difficult down on the job for non-professionals.
    I've just completed replacing the all the rain gutters and seal sections on the rear of a DS. The left hand side involves a gas butt weld of 0.8mm steel just on 1 metre long - something that would be challenging with a MIG.
    I guess the point is that if you want to do the job properly then you need to invest in the right tools.
    roger
    Oct 2002
    Melbourne Victoria
    11,873
    Icon14 Competition for BOC - Fantastic!!
    Very interested in this - have been renting oxy acetylene cylinders for years and had an account with CIG/now BOC. CIG allowed you to exchange cylinders without worrying much about the cylinder serial numbers, so if you acquired extra cylinders you could fill them and have a reserve supply. When the rental got a bit expensive a plumber mate and I used to swap cylinders and he had the acetylene and I had the oxy and with spare containers we would just fill oxy or acetylene as required ay CIG and as long as you had an account this was o.k. BOC cracked down on this and would only allow you to change over the type you had on your account and recorded the serial# of the container supplied, and then my plumber mate died, at some time I will need an acetylene fill so have to bite the bullet and pay rental of that gas. I would love to move to a new acetylene supplier and check out the economics of using their gas.
    So for me it will be a no brainer to make the move and BOC have only themselves to blame for the hard time they gave me when I filled my mates acetylene and they tried to charge me for the gas + cylinder and rental at the time and finally giving up when I refused to pay or disclose the lenders detail as it was completely above board arrangement at the time, we just made sure we filled our own cylinders after that, just a bit inconvenient.
    So a gas supplier without inquisition would be very handy as I like the convenience of using oxy acetylene gear, so I will be watching and waiting for Bunnings to extend this to Victoria - maybe BOC might just change their rental rates to accommodate and retain long term customers.
    Thanks for posting the info.!!
    Ken
    dvr
    dvr is offline
    697
    I've checked my local Bunnings. They only supply D bottles at the moment. $200 deposit for each. That's $400 refunded when bottles are returned or rolled over with refills. Much better than the $338 annual rental I've paid BOC for the last 15+ years.
    Refills are $99 for acetylene and $59 for oxy. So $20 more than BOC for acet and $15 more for oxy. For a low usage DIY like me it's a no brainer where I'm going once these bottles are empty.
    Great there's a viable competitor to BOC at long last.
