2CV on Gumtree
Results 1 to 8 of 8
Like Tree3Likes
  • 2 Post By jaahn
  • 1 Post By JBN
Thread: 2CV on Gumtree
    Jan 2011
    adelaide
    154
    Default 2CV on Gumtree
    Not Mine worst luck. 1977 Citroen 2CV on Gumtee at Maleny Qld. $3300.
    Oct 2012
    Armadale, Melbourne
    255
    16,417
    bet it's sold already
    JBN
    JBN is online now
    1000+ Posts JBN's Avatar
    8,231
    I can see why there is only 3 (not 4) photos of the car as the passengers front wing has some damage. That said, for that price it is a worthwhile buy if someone wants to build up a really good car. It is unregistered so it is either a private import that has never been registered (in which case you need the import papers) or it has been registered but the rego has lapsed. If it has lapsed for more than a few years, then it will have to be blue slipped and you will run into ADR issues.
    A car like this can be completely refurbished. Completely strip the car. Decide if the chassis needs replacement or repair. Get a later gearbox with disc brakes (renew all the braking to run on LHM rather than DOT3, new pipes, master cylinder, slave cylinders in rear, etc). Strip the suspension renewing/regreasing bearings. Repaint all components. Overhaul engine. Remove all rust from bodywork. Probably refurbish seats (new rubbers, upholstery). Maybe a new hood. Maybe a complete respray of the body.
    If you brought a car like that up to immaculate condition, you could probably get close to 20K. If you got it registered and painted the passengers front wing it would be worth about 14K. Either way, there is incentive to get it running and registered.
    John
    16,417
    I don't mind the battered look. If the chassis wasn't sound, I'd replace that and drive it looking like it does Some @sshole would just bend it the first time I parked it in a carpark if I got it looking all pretty (well as pretty as a 2cv ever could be )
    Newcastle
    2,620
    Hi,
    Following a link from that to a C5, I noted it had "Numatic Suspension", to coin a phrase
    Jaahn
    ScotFrog and addo like this.
    JBN
    JBN is online now
    8,231
    Hi,
    Jaahn
    The "Numatic Suspension" is a great improvement on the "Oldmatic Suspension" I understand.
    John
    alhantos likes this.
    Sydney, NSW
    427
    Default 2cv
    I agree with John. A steal.
    Completely do able in terms of a restoration.
    Could come up like new for not mega dollars.
    If I could store would snap up.
    Chris M
