CX Backfiring
Results 1 to 7 of 7
  • 1 Post By Fingers
Thread: CX Backfiring
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default CX Backfiring
    hi,
    My CX is backfiring during de-acceleration. I would have thought this impossible on an electric injection car.
    Anybody know what I should be looking for to fix it?
    Warren
    Fellow Frogger! Fingers's Avatar
    Old Junee NSW
    584
    Vacuum leak?
    addo likes this.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I will check all of the hoses.
    16,416
    popping on the over-run shouldn't happen. I can get the turbo to pop nicely on the overrun by gently touching the throttle.
    You see if the engine is doing more than 1800rpm and the throttle is shut (ie: the throttle spinal in closed) it chops the fuel injectors out. So all you need to do is check the accelerator cable is allowing the engine to drop back to idle, and make sure the idle/full load switch on the throttle spindle is working.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Thanks Shane,
    The throttle cable has a few broken strands and, it isn't going all the way back to the stop. Its' idle speed can vary between around 800 and 120 rpm during a drive so, that will be the problem.
    cheers
    Warren
    Jun 2012
    85
    Onlytime I've had backfiring problems was when I put bad fuel in the car (less than 95)
    16,416
    carby CX's will pop and cackle on the over-run, but only if you don't have a rear resonator fitted. outright backfiring should never happen with any of them though.
    Another issue with the injected one above could be the engine mounts. If the engine is moving a large amount due to collapsed mounts, it'll pull/release on the accelerator cable, and twist/flex the inlet tract, possibly allowing un-metered air in after the AFM.
