2004/2005 Citroen C5 Dashboard Display
    266
    Default 2004/2005 Citroen C5 Dashboard Display
    Hi
    The Dashboard disply on our C5 has lost its lighting. Does anybody know how to fix it. Is the bulbs behind the display that can be changed?
    Regards
    Alan
    Newcastle
    2,623
    Hi Alan
    Yes there are several bulbs. Not too hard to do. I will look up the book for the hints and get back.
    Jaahn
    266
    Jaahn
    Thanks for your help
    Regards
    Alan
    Newcastle
    2,623
    Default Global answer ! :)
    Hi Alan
    The book says ;
    Disconnect the battery. Probably not really necessary. Just turn the ignition off.
    Using a blunt, flat-bladed tool, carefully prise up the lower edge of the cover and pull it rearwards. The cover is the plastic surround for the display. It has tabs underneath to hold the bottom in, so lift enough to clear the tabs so it comes out.
    Undo the 2 retaining screws and remove the display unit. Disconnect the wiring plug if required.
    Easy !
    The 3 globes are in the 3 plastic holders which are twist and remove from the rear. The globes are those tiny push in type that have the wires just folded back over the glass at the base. They pull out of the holders. I think I determined there are two wattages and the more powerful is the type.
    Good luck Jaahn
    266
    Jaahn
    Thanks very much. That a great help.
    Really appreciate the help.
    Regards
    Alan
    Fellow Frogger! Clogzz's Avatar
    Mar 2005
    Sydney 2087
    189
    2004/2005 Citroen C5 Dashboard Display-display_1.jpg2004/2005 Citroen C5 Dashboard Display-display_2.jpg2004/2005 Citroen C5 Dashboard Display-display_3.jpg
    2003 C5 2.0i AL4 205,000 km 76372389
