Xantia won't start, 6 weeks battery disconnected.
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By Hotrodelectric
Thread: Xantia won't start, 6 weeks battery disconnected.
    Coffs Harbour, NSW, Australia
    616
    Default Xantia won't start, 6 weeks battery disconnected.
    My '94 Xantia auto won't start after having been idle for 6 weeks with the battery disconnected. I have had the dashboard out & have been unable to refit everything until this weekend for medical reasons.
    The security pad red light does not extinguish & the green light illuminate after putting in the correct numbers. Battery is fully charged. All other electrical functions work. As yet I have not refitted the airbag.
    Is there a procedure to follow that doesn't require a Lexia for reprogramming the security system ?
    HELP please !
    Richard
    16,415
    try the default code ..... 0000 ??? I think that's it either way. Have a look in the handbook. I didn't realise they could "forget" codes by disconnecting htem for a period of time though
    shane L.
    616
    Hoorah! Problem solved.
    I tried your suggestion Shane but it didn't recognise 0000, but when I tried the correct numbers again...success !
    My thoughts are that unlocking the driver's door with the battery fitted was the solution. On previous attempts the battery was fitted after the door was unlocked.
    I will disable it permanently from now on as it is a pain in a-r-e .
    Thanks Shane for your advice.
    Richard
    Don't remind me!
    16,609
    You know there is an "auto" mode (ie, immo bypass) for most of the keypads? It involves punching in the code, then three other inputs and I think it then holds until the constant power is removed.
    16,415
    woops, I shoudl have metioned locking/unlocking via the remote first up If you enter the correct code, then unplug the keypad, I'm pretty sure that will disable the code from then on.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,228
    Why do they make Citroens so difficult to steal when nobody wants to steal them in the first place?
    John
    San Diego, California, USA
    3,534
    John
    I think it's a matter of mindset mixed with pride and a bit of hubris.
    David M and citroenut like this.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    I had the same problem with an 8 valve. The immobiliser had been put into bypass mode by a dealer, but after a long period with a faulty fusebox and no power, it had reset to something else. I found 0001 ended up working for me and then I found a thread here that explained how to set the XM and Xantia keypads to bypass and was able to bypass it again.
    Ken W
    10,783
    Quote Originally Posted by Ken W View Post
    Ken W
    Delicious. Bet it wasn't at the time though.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
