CX window winder
Results 1 to 10 of 10
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default CX window winder
    Hi,
    Would anyone out there have a drivers side manual window winder that would fit an 85 GTI (or where I might find one)? I am going to have to wind the window by hand untill I can get to the door wiring....
    thanks
    Warren
    9,777
    I doubt you'd even find a manual front window reg here. They are all electric and late cars are different to early cars as you've already discussed in one of your earlier threads. Would you also punch a hole in the door trim for the handle??? Just leave the thing up until you can fix it and do the job once, properly.
    Feb 2013
    451
    Quote Originally Posted by WRB View Post
    Hi,
    thanks
    Warren
    Jam up one of the rear windows & use the mechanism in the front until required . Remove the map pocket carpet section & pop out the winder cover (or maybe the '85's don't have one?) otherwise you'll have to drive around without a door trim. But do you have rear electric? I have a set of manual winders. It sounds easier just to fix the wiring or by-pass the issue & use the cigarette lighter for the time being?
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    It is the wiring that is at fault so, moving one from the back won't work.... not being able to open the drivers window is really annoying but, I won't be to replace the wiring without removing until I have the dash out - I think - cannot work out where it goes once it enters the A pillar
    Feb 2013
    451
    Yes my suggestion would only work if you had manual rear's. The power comes direct from the switches into a well wrapped loom. One relay activated by the ignition powers them (check it too)
    Does the electric mirror work? That would give you a live positive & simple to wire in a momentary rocker switch direct in the door for the time being. As Gerry or Shane have suggested the opening & closing of door has degraded the wiring specifically in the join area. Use a meter & check you have power at the switch plug. 5 pins. No.3 positive, 2&3 negative. 1&5 go to door. Does the fuse keep blowing? Do any of the other windows work? I had a dash fire due to the heater controls rubbing the blower positive against the sharp gearstick mount under the gaiter. It's very tightly packed under the console. A new lead connected to pins 1&5 direct to door following the speaker wire could solve it?
    16,426
    what year CX is it ?? If it's an earlier one the wiring comes straight out of the pillar and into the door. If it's this type, there wire will be broken at the flex point in the door opening. If it's the later type (exits the pillar and one height, and enters the door at a different height) the wiring shoudl then be fine (as it marginally twists the wire rather than flex it in one spot). If this is the case, check the fuses have contact (they won't be blown, they could be intermittant in the fuse holder though). Check the window relay above the battery, and finally the swithc..... it's most likely to be the switch, if the passenger side works, swap the switches over and see if the drivers side now works. You can whip the switches apart and clean the contacts.
    Fellow Frogger! denxm's Avatar
    uki aust
    450
    as shane said, swap the switches,my old cx had a fault on pass window, swapped drivers switch over,it worked, pulled faulty one
    apart, a good clean then it worked, also had a broken wire at the door opening one time.
    Feb 2013
    451
    Series I CX switches are cheap enough, just remove the chrome surround & add it to one of these:
    http://m.ebay.com.au/itm?itemId=400612438217
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    It is getting power to the motor, just not enough. The other windows come down very slowly and need help getting back up again. The central locking is very slow and, I keep it unlocked as it has locked me out a couple of times.... The battery is not well and so, that won't be helping. I will replace that first and then worl methodically through all of the wiring.
    16,426
    yep, voltage drop... check the fuses and battery terminals (ie: the power feed over to the black plastic distribution box beside the battery).
