1.6 HDI Injector issue
Results 1 to 3 of 3
    May 2014
    1
    Default 1.6 HDI Injector issue
    I was reading a C4 forum and came across a post about the fixing bolts on the injectors becoming loose over time and possible engine damage occurring Just checked mine and 3 of the injectors had loose fixing bolts only a little more than finger tight. As this can lead to very expensive failures I thought it worth a mention it may have come up before on this site ,but as Im a newbie I couldn't find anything. Defiantly worth checking PS engine running smoother since they were tightened .
    sorrento
    98
    Yes, this leads to a leakage of fuel past injector (esp on apparently No 1 & 4 Cylinders, UK C4 site) ,we could see and smell fuel , which then leads to injector becoming frozen in the head (Carbonisation around injector ?) Fix is 2 cheap seals if you can extract the injector. If injector is destroyed in this process ie removal they cost about $800 +. Known problem with some Fords and BMW/Mini that share similar engine and also many others according to my diesel mechanic ,fortunately he was able to eventually remove the injector without damage !!
    1950 Light 15 - Blanche 'Claude'
    1949 Light 15 - Noir 'Emilie'
    1982 2CV Special - Lagune Bleu 'Daffie'
    2007 C4 HDI EGS - Rouge Lucifer
    1968 Velo Solex 3800 - Noir
    Member mork63ukCGAT's Avatar
    Jan 2006
    Hull UK
    75
    signs can be chuffin sound and a hard black tar substance leaking out of the injector hole. I had this on my Picasso, I got the motor very hot and whlie the tar was soft, I managed to pull the injectors out. the copper washers were destroyed and had to be replaced... after the seat was recut.. job was a good one
