lower ball join play
Results 1 to 9 of 9
    geelong
    71
    Default lower ball join play
    Hi Everyone,
    spent two days trying to undo lower ball join nut holding the seating ,spacer and ball together. I made up 3314_t special tool and freed the press metal from the slots.So far no luck. It just does not move and keep shearing three pins from the tool. Maybe I'll try tomorrow with high tensile pins.
    Q: Anyone knows what is allowable if any, horizontal ball joint play?
    CitroŽn Tragic UFO's Avatar
    9,721
    Give us a clue on what model you're working on.
    geelong
    71
    Sorry gays I forgot to mention I'm working on 74' D special
    Don't remind me!
    16,609
    Ahem! I'm sure a few straight people might be interested in helping, too.
    Are you holding the driving flange down tight with the centre bolt? I'd have thought that getting it "FT" there, might assist. Also try some shock with sharp blows from a lump hammer and drift, before fitting/tensioning up the tool.
    Coffs Harbour, NSW, Australia
    619
    No phobias here. Straight people are quite nice once you get to know them !
    R.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,069
    The tool really needs to have high tensile pins. Have you cleared the metal from the slots that the pins engage .
    Note dowel pin 14 in the diagram.
    Cheers Gerry
    geelong
    71
    actually there is no dowel pin according to manual 814 and visual.
    3,069
    Quote Originally Posted by adjole View Post
    That pic was taken straight from the spare parts manual. It has been a long time since I performed this job on my old D Super 5 so my memory is getting a little bit rusty. I had to make my own extractors and remember that the unit sat over the ball pin stem and the nut was put back on to the ball pin to prevent the tool lifting off the surface of the ring nut under the spanner torque!
    Cheers Gerry
    geelong
    71
    Gerry I'm not shore I got right manual but this page is from 814 manual and actual picture of the nut.Cheerslower ball join play-img_2157.jpg
