A. Qustion 1961 ID19
Results 1 to 9 of 9
  • 1 Post By DoubleChevron
Thread: A. Qustion 1961 ID19
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    Default A. Qustion 1961 ID19
    Hey all, I was just day dreaming again.
    I saw the vision of rear wheel spinning even break was applied. Rear of car is on stand by the way. Break is not working????
    How can you check that?
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
    16,426
    Your pulling our legs right ?
    caparobertsan likes this.
    Mar 2005
    877
    The rear brake cylinders are probably seized. Stuck from lack of travel/work.
    Easy to disassemble. The only trouble will be to recentre the brake shoes on the eccentric mount, so don't disturb if the shoes are wearing evenly. Once you take it apart it will appear terribly simple.
    I cannot remember if your car has master cylinder non powered brakes or the system that uses the rear suspension pressure to energise the rear brakes. They usually seize up from lack of use or load carrying to make the cylinders actually DO something.
    Mar 2005
    877
    Just re read your post. If there is no weight on the rear of the car ( it was up on stands ) there will be NO pressure supplied to the rear brake circuit ( a power braked system ) ... if you have the master cylinder high pedal system I believe the wheel cylinders will just be all gummed up.
    May 2011
    SOUTH MORANG
    793
    I just had a flashback. But I remember someone said something and I did not worry about it. I was just wondering.....
    May 2011
    SOUTH MORANG
    793
    Quote Originally Posted by fritzelhund View Post
    Thank you.
    Now I can sleep.
    16,426
    I thought he was being silly by saying the back wheels still turn with the handbrake on .............. Either way, it'll pay to bleed nice fresh fluid back there if you have never bleed the back brakes
    May 2011
    SOUTH MORANG
    793
    Thanks Shane .... I need that plug switch.....
    16,426
    Quote Originally Posted by caparobertsan View Post
    Hydrualic pressure? I sent that yesterday. If it's not leaking, it doesn't really matter either way
