CX Help
Thread: CX Help
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default CX Help
    Hi all,
    Can somebody let me know how you adjust the tappets on a gti 2500? There doesn't seem to be any way to rotate the crankshaft and the Haynes manual only shows it being done with the engine out of the car.....
    Warren
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,069
    Quote Originally Posted by WRB View Post
    Hi all,
    Warren
    Jack up one side of the vehicle so that the front wheel is off the ground!
    Remove the injection manifolds and rocker cover!
    Remove the spark plugs! Put the car in 5th gear.
    Use the wheel to rotate the engine via the gearbox.
    If you have an Auto forget the above except for manifold rocker cover and spark plug removal.
    There is a red sleeved single pin wiring connector just near the positive terminal of the battery. Disengage the male part of this connector and touch it to the positive terminal. This engages the starter and rotates the engine to the desired position for valve tappet setting!
    Cheers Gerry
    Fellow Frogger! Rob T's Avatar
    Oct 2002
    133
    I leave my car on its wheels. Simply put it in 2nd gear and roll it to turn the engine over. I don't bother to take the spark plugs out. Takes a bit of effort and you have to wait a bit while compression bleeds down as you go thru the compression stroke. You can do all four cylinders in two engine revolutions - about 1 metre of travel along the garage floor. Of course you need a level floor for this method.
    You can also turn the engine by levering on the flywheel teeth thru the timing light hole. Use a big flat blade screwdriver. You only get a couple of teeth at a time. Slow but do-able.
    I check the clearances in my car every couple of years. They have always been a bit tappety, but the clearance is always very stable and doesn't seem to wear significantly. My car is now at 350,000 km and all it gets is an oil change at ~5k intervals. Make sure you use an oil for 'older' engines. The modern lightweight synthetic oils do not have the right viscosity or additives for these engines. I use the original Castrol GTX most of the time.
    Robert Thorne
    Citroenless - for now...
    Oct 2002
    133
    Robert Thorne
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Thanks everyone,
    I will use the "5th gear" method.
    cheers
    Warren
    16,426
    What if the car is an automatic or C-matic ?? You'll need to access the ring gear. If the cover is off from below, then your set. Otherwise, remove the flywheel sensors and proceed from above with along flat bladed screwdriver. Remove all the spark plugs first!
