LED replacement bulbs
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By Hotrodelectric
  • 1 Post By pug206gti
Thread: LED replacement bulbs
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    563
    Default LED replacement bulbs
    Hi all,
    I need a new brake light globe for my SM. Can anyone advise me on the size, type and spec as I don't want to undo the fragile screws twice. They are not as bright as they should be and I am thinking of fitting LED bulbs. Anyone done this and is it easy/ worth it? If so what type and where are they available from. Any advice gratefully received.
    cheers Tony
    Don't remind me!
    16,609
    Hi Tony, in your fairly specific situation I would look for NOS bulbs from the later eighties. I think my Mi16 has 80% original globes in the rear cluster after 25 years. My own experiments with LED arrays have typically seen one of a pair let go within 2Ĺ years or less, admittedly low cost sets.
    8,410
    I'd agree about the old bulbs lasting forever, but can add an interesting observation...
    About 6 years ago I changed my number plate lights to LED for a bit of bling.
    The guy at jaycar suggested these bulbs were not really suited to external use, so taking that advice on board, i covered the LEDs with neutrlal cure polycarbonate sealer (silicon).
    They are still burning strong years after the non-coated lights fitted to the interior crapped out.
    Jo
    San Diego, California, USA
    3,534
    Tony, the spec for the lamps are: standard "bayonet" base sized like an 1156 single filament bulb, 21 watt draw. The French standard number is R.136-12, and the 'international' number is P.25/1 . I would not go any larger than the 21 watt draw- you run the risk of melting some very expensive plastic.
    LED is a good idea- you get the brightness with the reduced draw. The only problem is nobody reputable, like Sylvania, Osram or Philips make them. They're all from some slightly shady company located somewhere in the East. Despite Jo's good luck, you will probably have to change them out every few years.
    If you go Adam's suggestion, try to find bulbs made in France, made in USA, made in Germany, etc. Don't go for the stuff made in India, China, et al. You will be disappointed.
    Leconte likes this.
    3,534
    Tony, I just spotted this web page in another thread, courtesy of Richo. You might be able to find what you're after here:
    Page Title
    Here's hoping I'm wrong and the quality has improved on the LED bulbs.
    16,414
    I have used LED's in the CX dash (as I thought they'd last forever and save swapping them). Recently I changed all the blown globes (again) and most of the LED's had fried themselves in less time than the globes. I'm sure there's quality LED's out there, but how would you pick them
    Over the last 5years however, I've changed every trailer I've had my hands on too LED's ........... and have never had too touch them again. There vastly superior to those cheap nasty trailer lights.
    Sahen L.
    10,783
    Sahen L.
    I presume it is the stuff the LED is attached to that fries?? They ought to be almost totally reliable. Pity to hear they aren't, as I was thinking of going that way with the CX myself.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1,475
    Tony, I have LED bulbs throughout the interior (including the ashtray) so everything can be seen inside the cabin at night - especially that fast dropping fuel gauge!
    1972 SM
    1989 BX 16 Valve
    lost
    11,055
    Icon6
    G'day,
    off on a tangent, that well known letter delivery corporation that features in the news nearly every day lately, recently issued new uniforms to the staff. Look closely at your Postie next time he/she is around. After one wear and one wash the shirts are pilling. I think that is the right word.
    Pill (textile) - Wikipedia, the free encyclopedia
    No prizes for guessing where the gear is made.
    artisan likes this.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Mar 2005
    877
    While not applicable to any classic Citroen there is a trap for young players with using LEDs. The cruise control doesn't like them on my Mitsubishi. It fails to create enough draw when the stop lights are lit ( and that is necessary to cancel the preset speed ) .. I suspect LEDs in a C5 or newer would cause havoc too. I note some on Ebay are said to not upset the CANBUS system, and assume they have a resistor built in for that purpose.
    I have also replaced the LEDs in my caravan tail lights too. They are just not bright enough in daylight for following traffic to notice the difference despite being supposedly made for the purpose. One LED clearance light has stopped working already too, so they are a bit of a mixed bag in quality/reliabilitylifespan.
    10,783
    I have had LED brake lights in the Renault 4CV for years, and the side flashers. One great benefit is that they come on really sharply (think square wave) compared with heating up a filament, so are more noticeable as brake lights. I'd try them in the SM for that reason alone. Buy four so you have spares.
    Renault 4CV 1951
    Renault R8 1965
    Apr 2014
    Phoenix, Arizona USA
    674
    A word of caution about using LEDs in the DS instrument panel. The Citroen twist socket for the bulbs will short circuit across the connector for many LED wedge-base bulbs. This will immediately fry the flex circuit on the back of your instrument panel (don't ask me how I know this). There is one supplier in the US (superbrightleds.com) that supplies LEDs with a twist socket that fits the DS instrument panel but will not short circuit across the LED. Look for the P/N WLED-GHP5-PC3 (the PC3 suffix means the twist socket is supplied). The alternative is to get the plastic wedge base LEDs and trim the leads so that they do not wrap around the wedge base
    John T.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    I tried stop/tail LED globes in the CX. I tried to have one side with conventional and one side LED for comparison purposes. However the LEDs would only work if both were LED. If they were brighter than normal I couldn't tell. She is wearing conventional lamps in the taillights now. Problem with the ones I had was most of the LEDs were firing sideways in the fitting and the less than good reflector in the light unit did not help there. You can find some that have most of the LEDs facing away from the socket but I wonder what pattern of light that would give viewed from outside. Proceed with caution as others have indicated.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
