CX window motor - Page 2
Page 2 of 2 First 12
Results 26 to 32 of 32
Thread: CX window motor
  1. #26
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,079
    IIRC they are actually called window regulators, not winders or motors.
    Anyway, when we had Celeste CX, one of the first jobs was repairing the lazy driver's window regulator. It was as Rob T suggested failing electrical cable - the cable had in fact broken internally and the insulation was not far off too.
    Also a lazy battery or alternator can slow down window movement. Do the windows go up and down faster with the engine running at >1500rpm?
    Then clean the switch internals while you're at it. Remove the switch and douse with isopropyl alcohol.
    The Americans call them regulators. The motor would then be a regulator motor!
    Cheers Gerry
  2. #27
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Hi,
    the battery, alternator and Regulator are fine (the window dropped down when I removed the motor and the grease is still good)
    so, I will put the motor back together, and re-do the wiring. After 25 years, I imagine all of the wiring will have some corrosion in it.
    cheers
    Warren
  3. #28
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    The speed of the motors doesn't change at any revs so, wiring.
    And that is another difficulty. How do you access wiring in the a and b pillars??
  4. #29
    3,079
    B Pillar trims are held with small plastic clips. They Break easily! Be careful!
    A pillars can be accessed more easily. But you mat need to remove the dash panels on either side. The metal flocked panels only!
    Cheers Gerry
  5. #30
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Thanks Gerry
  6. #31
    Fellow Frogger! Rob T's Avatar
    Oct 2002
    133
    Just another thought. The switches themselves suffer from old / dirty / corroded contacts internally. The switch carries full motor current (about 5 amps?) so high resistance contacts can have a significant effect. I have pulled the switches apart for cleaning in the past. But I have also had good success with pressure pack contact cleaners. No need to dismantle the switch. Just poke the tube into the internals and spray liberally. Electrical contact cleaner is available in small pressure packs from places like Jaycar.
    Robert Thorne
    Citroenless - for now...
  7. #32
    16,466
    check the relays around the battery too.... I bet the voltage drop is across the relays and there power feed. The switches seem to either work ............ or not work.
    seeya
